3 members (MartinB60, rossocorsa, BertL), 170 guests, and 72 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
Page 4 of 8 1 2 3 4 5 6 7 8
I keep seeing weight in this construction. I wonder how much weight? I am guessing about 2,000 lbs. But it could be more.
Button
Thanks ! One of the reasons I choose the Duratec is due to the exhaust of the passanger side.
It is light, last weight 95% complete with all and half tank was 1433 LBS , 650 kg.
/Carl
More Pictures:
I had to fabricate my own clutch slave cylinder , the OEM one did not fit.
Floors , firewall alu skinned and fitted. Handbrake lever and gearlinkage fabrikated.
Nice stance , Engine , gearbox etc is still only in "mock-up" phase:
I did not like the cheap red plastic "key" for main powerswitch so I made my own in the lathe,
So much talent on display well done that man. This is going to go like a rocket and handle smile
Coolingsystem is beeing built:
Fabricated coolerhose adapter with tempsender:
Wiringharness for the fuelinjection in a very early state , its been fitted with a Maxxecu injection/ignition system:
Stainless exhaustsystem beeing built , I wanted it completely hidden under the fender.'
Hard to see in the Picture but be rear fenders have been widend 50 mm / side:
Driverseat testfitted
Fueltank fitted , I found a used original Morgan gas-cap that I used:
Testing the digital dash :
Engine cleaned and ready to be fitted :
More work on he bodyparts , you can see that I "lowered" the fender/sill 40 mm and also lengthend the rear fenders,
I did not have any hinges for the doors so I decided to fabricate my own from a raw piece of aluminum:
Upper and lower:
Such talent.
Giles. Mogless in Paris.
Absolutely brilliant work, nice to see you are using safety retaining washers on the Rose joints too ( pretty sure I see them in a least a couple of photos) it’s a small but significant detail that many people miss when doing work like this. Attention details like those door hinges and the isolator key are the mark of a real craftsman too.
You are going to have one hell of a good car when you are finished. Well done 👍🏻
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Originally Posted by pandy
Such talent.
Thank you !
