0 members (), 272 guests, and 25 robots.
+8Rich 94
Posts837,276
Yes that was the idea.... Indeed they are not perfect! Maybe they need to be redone by a pro...
2009 Morgan 4/4 Sport
jbk Offline
Not sure a pro would fare any better, position of clips is limited by where the gap narrows, if you position the apex of the mesh to the top of the lamp, which it looks like you have ( my rims have a dot at the top) then the mesh will be at an identical angle with each other, I don't have a mesh grill so cant comment but I have fitted 5" spot lamp mesh having made up aluminium clips (only 2 on each lamp) and looks ok to me.
As for cleaning, if you bend over one (bottom ) clip it is possible the unclip the other two and swing down the mesh.
The real issue with the clips is they could do with being a bit longer and just a little narrower.
1993 T16 +4 Lancia Blue.
I set mine on the diagonal to match the grill .....worked for me[Linked Image]
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
To me the grill looks vertical...
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
laugh2
innocent
Magwa
