7 members (Strathaven, Deejay, BLUE+4, Simon, John V6, B3MOG, B&C Morgan),
201
42
Topics49,859
Posts837,498
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Thanks guys....I have just seen that there was some sort of factory recall for the type of pedals I have and with your warnings I will contact our main dealer here in Sweden.....The best will probably be to get the new modified pedals and then see if I can change them and the setup the same way.
I have only been here on TM one day and already got a lifesaving tip:-)
As for learning to post photos that will be a slow process, they should really make it faster and easier for people like me.... Lots of good information to read here on the Recall regarding chassis cracking and the peddle box so stay tuned. You have clearly recognised how important this is. Enjoy
Posts: 400 |
Hey Swede, where are you located?
Finns i Stockholm, själv...
Regards, Nik
M3W, now!!!
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Wishing you good luck with the recall notice on the pedals.
Keep us in touch with how you go with your dealer and don't forget to get your service book stamped. Good for you to have a clear record and reassuring for a new owner should you sell in the future.
Posts: 107 |
Hi again...
I will keep you posted on what happens with the pedals!! I will also make sure that I get some written confirmation/service book stamps......I had mine in for the chassis modification two years ago but that was not noted in the service book....
I have also made the whole torque converter?/stator/rotor/regulator re-build but that was done by a motorcycle specialist and not by the dealer....but that is documented with invoices and pictures......
DocNik....Im in Nyköping...just one hour south of Stockholm! Good to see another M3W owner so close....:-)
Swedewheeler, you are lucky to have a dealership so close! I am about 700 miles from a dealership. This dealership is no longer selling Morgans. ![[Linked Image]](https://www.tm-img.com/images/2019/06/29/Morgan-Arrival2.jpg) I pick this car up in 5 days
Hi again...
Great work Swede. Good to see you are all over this important issue.
Posts: 400 |
Hi Swede! Close, indeed! See you at the meets in Nyköping harbour? July 10th is convertible night and July 31st is British night...
M3W, now!!!
Posts: 107 |
LightSpeed. 700 miles....That´s painful.......Car looking great though....I wish you all the best with your new car and that you don't have to take it to the dealership that often......What year model is it?
DocNik....I will try one or the other....if I can get my M3W back together again before that....:-) I had a "clonking" noise from the rear so I have taken it apart to check rear wheel bearings, bevel box and sprockets, belt etc What annoys me though is the it all seems fine.....I still suspect the wheel bearings however....that they make the noise when warm and under load. I will also change the oil in the bevel box now when I have full access. I will let you know if I can make it to one of the meetings in the harbour.........
Posts: 107 |
New try posting pictures.... ![[Linked Image]](https://www.tm-img.com/images/2019/07/03/IMG_6333.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/07/03/IMG_6334.jpg)
