7 members (Ambrose2, TBM, JMcL, sewin, IcePack, Richardllll, Plus Four Guy), 88 guests, and 22 robots.
John V6 63
Silicon cf. Silicone
by JMcL - 24/09/26 10:21 AM
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
First Morgan as it is now
by Strathaven, September 15
Topics49,941
Posts838,613
Page 4 of 4 1 2 3 4
John V6 Offline OP
I did think about that but am worried if it breaks off & gets sucked into the engine.I might though use vaseline
You might be able to get a spun aluminium flanged tube which would fit inside the fibreglass section...……..
Demon Tweeks or similar sell such things.
Vaseline would work but goes quite fluid when hot
My choice would be Blue Hylomar, used it for years, handy for domestic plumbing too
John V6 Offline OP
Dave I was thinking of doing that on the outside. The inside is not round & not a standard size. I was worried I would then have to reduce the inlet diameter & thus restrict air flow.
Jon yes I blue Hymolar in stock. If it keeps coming up with pending faults when I have the breather & T piece to spec then I may go that route.
John V6 Offline OP
So far so good. Pending fault has not reappeared.
John V6 Offline OP
Today I fitted the brass 10-12-10 t piece from ebay via China. This replaces the plastic 12-12-12 fitting I bought when the old one broke up on removal.
All is now fitted and so far so good with no pending or actual ECU faults
The t piece fitted and the last rocker breather to be added.
John, looks decent quality, but no clamps on the pipework ??
John V6 Offline OP
Didn't have them before. If I get issues then I'll fit some.
Page 4 of 4 1 2 3 4
