11 members (TBM, nick w, nestor59310, jbk, vbalddave, 2949olivier, Fuel.inj, Montegue, Image, Alan Patterson, Strathaven),
320
40
Posts837,283
Posts: 79 |
Yes that was the idea.... Indeed they are not perfect! Maybe they need to be redone by a pro...
2009 Morgan 4/4 Sport
Posts: 832 Likes: 28
Posts: 832 Likes: 28 |
Not sure a pro would fare any better, position of clips is limited by where the gap narrows, if you position the apex of the mesh to the top of the lamp, which it looks like you have ( my rims have a dot at the top) then the mesh will be at an identical angle with each other, I don't have a mesh grill so cant comment but I have fitted 5" spot lamp mesh having made up aluminium clips (only 2 on each lamp) and looks ok to me.
As for cleaning, if you bend over one (bottom ) clip it is possible the unclip the other two and swing down the mesh.
The real issue with the clips is they could do with being a bit longer and just a little narrower.
1993 T16 +4 Lancia Blue.
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
I set mine on the diagonal to match the grill .....worked for me ![[Linked Image]](https://www.tm-img.com/images/2019/07/11/SNB12147_zps349d0e06.jpg)
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
To me the grill looks vertical...
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Posts: 970 Likes: 1
