6 members (CJB, +8Rich, Graham, G4FUJ, Stevo666, AlyMatt, Saxonian),
242
84
Topics49,877
Posts837,728
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
find them and kill them GGGRrrrrrrrrr Hulk smash It is only a car... a nice car, but a car!
Posts: 27,822 Likes: 749
Posts: 27,822 Likes: 749 |
Bad luck Peter but it can be fixed.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The Chips Away man quitted £180 to blend the paint in and clear coat the panel, including removing the rear light unit and reflector. MG Cannon want £600 to do essentially the same thing. Can't decide which to use. The difference is significant. I'm tempted to use the Chips Away guy and if the job isn't goo get Cannon to re-do it.
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
We used Chips Away to repair some fairly heavy scratches on the wing of SWMBO’s 911 after a heavy wooden gate swung closed as she was driving through. They did an excellent job and the repair was invisible, they also did it at our location so no hassle of having to take the car, leave it and collect it later. I’d definitely use them again....though I hope I never need to !
Steve L.
1996 Plus 8 N22 MOG
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Really sorry to see that. To me there's no excuse, surley someone must know they've done it, unfortunately I think all too common these days. You are certainly taking it a lot better than I would have, at least the wing isn't damaged, just your wallet. Good luck with the repair.
Worthers +8
Yes agree You are taking it well I’d be loosing it, getting CCTV, police helicopters, SAS, MI5 and vigilante groups involved
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
I think i've got some brown in a rattle can on a shelf in the shed. Sprayed and coated in clear yacht varnish for £50 Peter.
Seriously i'd give the chips guy a go, or you'll never know if you could have saved £400+.
Posts: 300 |
Don’t think I could take this as calmly and pragmatically as you have - although a discussion with my Carer and counsellor ( Swmbo) would probably have taken me nearer to where you are.
If it was mine, I’d definitely go for the chips away, and if it was not good, then go for the £600 . On one hand you might be £180 out of pocket, on the other you could have £400 to buy petrol with...
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
The Chips Away man quitted £180 to blend the paint in and clear coat the panel, including removing the rear light unit and reflector. MG Cannon want £600 to do essentially the same thing. Can't decide which to use. The difference is significant. I'm tempted to use the Chips Away guy and if the job isn't goo get Cannon to re-do it. Peter,as you are probably aware,Chipsaway is a franchise so only as good as the guy doing the work. I would check with other customers to make sure you are getting a good 'un  That said, they can and do do some amazing smart repairs.I don't know if it is still the case, but they used to used a fairly thin lacquer (PC52) to blend the repair onto existing lacquer. This was not a two pack and was prone to dulling over time and could also be affected by e.g. petrol which could dissolve it! This was a few years back before they went to water based so it may have changed  Most body shops, if doing a part repair, use an agent to 'melt' the edges of the existing lacquer slightly and allow the new , two pack lacquer to blend in. James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
If it was non metallic, I would tackle it myself as I got a good result on mine when I scraped my wing last year but my attempts on a bit of a scrape on my Metallic grey Beemer were a bit woeful
Got away with it when I returned the car to the leasing company but was never happy with it
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
The repairs on my +4 are estimated at almost £25k don't think chips Away would cope with that, still awaiting the insurace Co to approve or not
