2 members (Ruut Bianchi, TBM),
94
Old Book
Topics49,940
Posts838,607
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
I did think about that but am worried if it breaks off & gets sucked into the engine.I might though use vaseline
Posts: 22,387 Likes: 359
Posts: 22,387 Likes: 359 |
You might be able to get a spun aluminium flanged tube which would fit inside the fibreglass section...……..
Demon Tweeks or similar sell such things.
Posts: 8,728 Likes: 514
Posts: 8,728 Likes: 514 |
I did think about that but am worried if it breaks off & gets sucked into the engine.I might though use vaseline Vaseline would work but goes quite fluid when hot My choice would be Blue Hylomar, used it for years, handy for domestic plumbing too
Dave I was thinking of doing that on the outside. The inside is not round & not a standard size. I was worried I would then have to reduce the inlet diameter & thus restrict air flow. Jon yes I blue Hymolar in stock. If it keeps coming up with pending faults when I have the breather & T piece to spec then I may go that route.
So far so good. Pending fault has not reappeared.
Today I fitted the brass 10-12-10 t piece from ebay via China. This replaces the plastic 12-12-12 fitting I bought when the old one broke up on removal. All is now fitted and so far so good with no pending or actual ECU faults ![[Linked Image]](https://www.tm-img.com/images/2019/07/26/20190726_110807.jpg) The t piece fitted and the last rocker breather to be added. ![[Linked Image]](https://www.tm-img.com/images/2019/07/26/20190726_111129.jpg)
John, looks decent quality, but no clamps on the pipework ??
Didn't have them before. If I get issues then I'll fit some.
