2 members (+8Rich, ScotiaSteve),
314
101
Topics49,860
Posts837,484
Posts: 79 |
Perfect!! Thank you for this!
2009 Morgan 4/4 Sport
Posts: 3,727 |
Good afternoon to all! One question I've had since I bought my 4/4 sport n May is that the front badge will not sit flush with the cowl. Is that a normal thing? How would I go about rectifying it? (please forgive the dust on the car :-) ![[Linked Image]](https://i.ibb.co/bWJ3L8D/IMG-2048.jpg) ![[Linked Image]](https://i.ibb.co/Swq7Vb0/IMG-2047.jpg) ![[Linked Image]](https://i.ibb.co/3MrZsTW/IMG-2046.jpg) I had this problem with a Warranty Replacement Badge (changed because the paint fell out) I complained to the factory as it is NOT CORRECT. The changed it for me during a factory visit but I had to give back the 'Flat' one. It is worth writing to them with a photo and ask for a replacement If you try and bend it yourself it could brake and it may never be right Frank
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
You could mount the badge on a body coloured vinyl pad that will take up the gap, I have the old style badge that cut into the paintwork on the wing tips so after re-spraying the cowl the badge sits on a soft cushion rather than on the paint. You could trim the vinyl to the exact size of the badge or make it 1/8 “ larger.
1993 T16 +4 Lancia Blue.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Thanks Rich. A well priced Item as usual from Morgan.!!!!!
Posts: 79 |
You could mount the badge on a body coloured vinyl pad that will take up the gap, I have the old style badge that cut into the paintwork on the wing tips so after re-spraying the cowl the badge sits on a soft cushion rather than on the paint. You could trim the vinyl to the exact size of the badge or make it 1/8 “ larger. That is an interesting idea, thanks!
Posts: 79 |
Good afternoon to all! One question I've had since I bought my 4/4 sport n May is that the front badge will not sit flush with the cowl. Is that a normal thing? How would I go about rectifying it? (please forgive the dust on the car :-) ![[Linked Image]](https://i.ibb.co/bWJ3L8D/IMG-2048.jpg) ![[Linked Image]](https://i.ibb.co/Swq7Vb0/IMG-2047.jpg) ![[Linked Image]](https://i.ibb.co/3MrZsTW/IMG-2046.jpg) I had this problem with a Warranty Replacement Badge (changed because the paint fell out) I complained to the factory as it is NOT CORRECT. The changed it for me during a factory visit but I had to give back the 'Flat' one. It is worth writing to them with a photo and ask for a replacement If you try and bend it yourself it could brake and it may never be right Frank Thanks for your suggestion Frank. Perhaps I should have mentioned thet the car itself is from 2009 (I bought it used) so way past it's warranty period...
