2 members (deano, Montegue),
223
74
Topics49,880
Posts837,761
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
I've been meaning to get around to this for ages. Here is version 1 of my “invisible” sidescreens. I think the Morgan looks much better without sidescreens but it gets pretty blustery at high speeds, so I’ve made one out of clear polycarbonate. It works well and feels like driving without screens (without the wind). Made this out of 10mm polycarbonate which is very rigid but was difficult to bend and it bubbled a bit internally when hot enough to shape (see the top right hand corner). I’ll try 8mm for the passenger side to see if it bends easier and is rigid enough in use. ![[Linked Image]](https://www.tm-img.com/images/2019/07/26/sidescreen.jpg)
Steve L.
1996 Plus 8 N22 MOG
Posts: 37,438 Likes: 984
Posts: 37,438 Likes: 984 |
They look good and preserve the nicer lines of the car but without the drafts, good luck with the 8mm.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
A great idea, but I do wonder if the material round the mounts will eventually crack. Perhaps 8mm but with 2mm stainless reinforcement laminated to the glazing below the leather trim line, and painted to match the car, might be the solution.
I made the slots longer so that the pressure isn’t close to the edge of the sheet, I also cut out slots in some penny washers and glued them to the polycarbonate so that the pressure is spread and not directly onto the plastic. Only time will tell how robust they are. When I’ve made the passenger side I’ll look at fitting some aircraft vents like the ones Kevfitz has used.
Steve L.
1996 Plus 8 N22 MOG
Posts: 465 |
Just don't forget they are there before you lean out the window!
Dark Red 4/4 80th Anniversary
Steve L.
1996 Plus 8 N22 MOG
Posts: 671 |
Very nice. I’ll be interested to follow this.
Posts: 938 Likes: 46
Posts: 938 Likes: 46 |
That is a nice idea!
How about asking someone who does screens for the small planes - I would not dare to try this on my own.
It was one of the first lessons on my ecomobile when I smashed the PC sunroof - nasty expensive slide of polycarbonate...
Miklos
1973 2CV AK400 Ralley 1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
Posts: 27,822 Likes: 750
Posts: 27,822 Likes: 750 |
Very nice idea. Keep us posted please
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
interesting conversion..I found polycarbonate great to work with in terms of cutting (jigsaw) and drilling and shaping.
