6 members (stumog, BLUE+4, Topline123, Stephen888, TBM, John V6), 345 guests, and 24 robots.
+8Rich 92
Topics49,838
Posts837,296
Page 3 of 5 1 2 3 4 5
Have A look on this belt very often
And after No problem
Originally Posted By 2Sharp
I am finishing up my cam upgrade and struggling a bit with getting the belt back on. Do you put both idler pullies back on before you route the belt around? I have the belt on but left off the one idler pulley with the lip to the front but having a very hard time to get the idler pulley back on with the belt on.
I have changed my belt and you put the belt on with the idler pulley with the lip removed and then put that on afterwards. Make sure the belt tensioner is held off with a spanner to release any tension on the belt.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I did this for the first time yesterday! Like you I had removed the right hand idler. Do you have the tensioner held in the non-tensioned position? I did this by holding the 11/16" spanner with my trolley jack.
Assuming that you have the allignment pins in the three cam pulleys and that the pinion pulley is alligned to FTDC, with a little huffing & puffing you should then be able to slip the belt into position. Then just hold the idler tight against the belt and you should be able to wangle the fixing bolt into position. If not, then the belt is probably a notch out somewhere. Good luck!
Andy
JFP Offline OP
yes, both idler pulleys should be installed before the belt is put back on. I had an assistant hold the tensioner wrench, so I had two free hands to work the belt. It does eventually go back on even though it seems to be too small. Good luck!!
1959 4/4 - sold
1957 +4 - sold
2017 M3W - sold
I've just looked at the S&S service manual (page 3-41) and it advises that BOTH idlers should be removed when fitting a new belt! This will make the job much easier in the future now that I've read that!
Andy
JFP Offline OP
Good to know for next time. Thanks!
1959 4/4 - sold
1957 +4 - sold
2017 M3W - sold
Thanks guys. Tried it multiple ways. The only way I got it to work is to leave off the front/top right idler pulley until the belt was on. What I figured out in all of this is one tooth off on the belt and the idler pulley is not going back on as the slack has to be up there. Easy job to do but you need to be patient. Fyi my belt had 1k miles on it and a few cracks and sent some pictures to S&S and they took care of me.
2017 M3W Sport Green
Just replaced my 2013 M3W a second time. First one broke resulting in an $800 midnight flat bed tow to a S&S dealer certified to work on the X-Wedge engine (surprisingly not many are!). After about 2,000 miles I noticed cracks on the new belt. So I bought another belt and the vented cover and this is what I did (obligatory: do this at your own risk warning):
Morgan Three Wheeler Cam Belt Replacement Instructions
Tools needed:
• Torx T-45 bit (preferably one that connects to your socket ratchet)
• allen wrenches
• regular open ended wrench set
• paint can or similar height stand
• THREE (3) STEEL 3/16” PINS. About 2 inches long. NO WOOD DOWELS! Machine shop
supply houses sell them, or your local hardware store may sell a long rod you can cut down
1. Work on a level surface, and set the hand brake, DO NOT put it in gear, (keep in neutral)
2. Remove license plate (two Allen bolts)
3. Remove front cam belt cover (4 Allen bolts) and you will see:
a) 2 Idler pulleys on top
b) 3 large cam sprockets (near top and middle)
c) 1 cam belt tensioner (lower middle)
d) 1 crank pinion sprocket (lowest)
4. Using your phone, take a few photos of what you see, to reference later
5. Use a Torx 45 (“T-45”) bit to rotate crank pinion sprocket until the little notch on that sprocket’s edge is pointing exactly at the “FTDC” marking on the surface next to it
6. Each of the 3 large cam sprockets have one 3/16 inch “cam sprocket timing hole” inside them, smaller than all the other holes. Those 3/16 inch holes should be aligned with (somewhat hard to see) drilled out holes in the plate behind them
a) Insert STEEL (DO NOT USE WOOD!) 3/16 inch dowels into each of those 3/16 inch holes – one per cam sprocket. This will lock the sprockets into place to preserve the cam timing.
b) If the pins do not go in, don’t worry, you can adjust the cams a bit after the belt is off and install them then.
7. Use a 17mm or 11/16” open end wrench to turn the bolt (behind a small washer) on the Cam Belt Tensioner clock wise until it comes to its stop (the “stop” is a small aluminum tab just to the left of the pulley). You are UN-tensioning the belt tensioner. Hold the wrench in place with a paint can or strap or what every you have.
8. Use an Allen wrench to remove the two Idler pulleys. Note: each pulley has a higher flange (edge) on one end to guide the belt. The left pulley has the flange on the back, away from you, the right side is reversed with the flange towards you. Each Idler pulley has a bolt and two special washers (each with a raised edge, more on that later). There may be a small rubber ring holding them all as one piece, or not (in which case the bolt & washers may slide apart).
9. Remove the belt. If possible, leave the wrench holding the Cam Belt Tensioner as is.
10. At this point, if you were not able to install the steel 3/16” pins into their respective holes in the cam sprockets, do that now. A little bit of rotating should be all that is needed. The pins should fit a bit snug and should not wiggle much. NOTE: if you use wood dowels, they may crush or wiggle, messing up cam timing and not allowing the engine to start. Don’t ask me how I know this…
11. With pins holding the cam sprockets, and the Crank Pinion Sprocket’s notch exactly at FTDC, go ahead and begin to install the new belt (with printed wording on it facing you). Use the photos you took as a reference or the back side of the exterior cam cover has a diagram on it as well. I started from the bottom up, but you can try any method that works for you.
a) Wind the belt around such that there is a minimum of looseness, make it snug, use a clothes pin where needed.
b) Getting the belt around the finally pulley or sprocket will require some but not severe effort. If it does not go, remove the wrench from the Cam Belt Tensioner and rotate the tensioner a bit, then reapply the wrench to UN-tension the tensioner and try again.
12. With the belt finally on, and keeping the wrench on the Cam Belt Tensioner (Tensioner is un-tensioned) you should have enough slack to relatively easily bolt on the two upper Idler pulley, bolt & washers. Apply 20 ft lbs of torque.
a) Note, if the Idler pulley, bolt and washers came apart during removal (ie the tiny rubber ring holding them together is missing) the washers have an indented edge that allow them to partially fit into the Idler pulley’s bearings and help keep the Idler Pulley centered around the bolt. If you bolt the Idler pulley on properly, you should see its Allen head is centered inside the pulley and NOT off center. If they are off center, the washers are not properly seated on the bearing, do it again. As you assemble the Idler, washers and bolt (if they came apart upon removal) you will see the logic.
b) Remember the left Idler pulley has it’s pronounced flange towards the engine, the right side Idler pulley’s pronounced flange is towards you.
c) The second Idler will require more pushing down against the belt to make sure the Allen bolt goes in straight.
13. Release the wrench from the Cam Belt Tensioner, and you will see the belt tighten up a bit.
14. Before attaching your cam cover (you bought the new VENTED version from S&S, right?) start up the M3W and see how everything is spinning around. If ok, turn off the engine and re-install the cam cover and license plate. Note, the new vented covers do not require the gasket.
15. Relax and have a Bourbon, Scotch, glass of milk, whatever you use to relax. You earned it. Use your old cam cover to serve pretzles, because no on on ebay will buy it.
and let me know if I missed anything here.
Well done replacing the cam belt Ferrisl. If you still have a crankshaft bolt with a T45 head I suggest you have a look at doing the upgrade to the camshaft drive that includes replacing the crankshaft bolt with a 12 point head type, or you may be needing the pretzel bowl again. The old style bolt tends to come loose and exit through the cam cover in a destructive way. With the loads involved it is better to use a Torx Plus 45 bit. The cam drive upgrade is well worth doing for reliability. The info is here:
https://www.mtwc.co.uk/wp-content/u...-Pulley-Replacement-Ver-1.compressed.pdf
Planenut,
Yes, I bought the replacement pinion and bolt but, after 8,500 miles of use, found the existing T45 bolt still very tight, so I did not replace it at this time. I will be monitoring the belt every 500 to 1000 miles and that pinion bolt as well. Thank you for the link, that is an excellent document!
