Topics49,915
Posts838,214
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
As this weekends weather was so poor I decided to try a wiper upgrade, I'm not keen on most of the alternatives that have been tried on TM as they are usually black and I wanted to stay chrome / stainless I managed to source these which were pretty close in length & nicely made ![[Linked Image]](https://www.tm-img.com/images/2019/07/29/20190727_094729_resized.jpg) Although very slightly longer, most in 'lost' in the inner sweep, mine just touched the 'screen top and needed a little trimming ![[Linked Image]](https://www.tm-img.com/images/2019/07/29/20190727_123414_resized.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/07/29/20190727_123649_resized.jpg) The centre one worked great but the other two ended up needing an additional tweak to loose I tiny bit of outer sweep, so by drilling an additional hole the arm would push further in & the button would still lock ![[Linked Image]](https://www.tm-img.com/images/2019/07/29/20190727_123403_resized.jpg) Overall pretty chuffed with the result, may even take them back off and mirror polish 'em ![[Linked Image]](https://www.tm-img.com/images/2019/07/29/20190727_125941_resized.jpg)
Posts: 27,852 Likes: 767
Posts: 27,852 Likes: 767 |
Jon where did you get them from?
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Jon where did you get them from? Nice job. I was going to the same.
Bud 4/4 "Stanley"
Jon where did you get them from? I've been searching on & off for years and tested various without a satisfying result, then by chance dropped on Carbuilder Solutions who I've used lots of times before & never noticed them in their book They are ref WBS 8
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
try spraying some water on your screen and see if you get a clean dry sweep.... if they work better than the mog standard landrover ones then im interested too!
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 638 |
Well spotted Cooperman - I think there will be a set winging their way to Cheltenham.
David H
Posts: 14,750 Likes: 158
Posts: 14,750 Likes: 158 |
I played around with a similar, but different, set of wipers and couldn't shorten them in a satisfactory way. These look a much better option.
If necessary it would be relatively easy to shorten the main rail and drill new holes to rivet the blade support closer to the centre. This would allow the blade to be cut shorter.
New rubbers could be fitted when necessary because they seem to use a standard type of rubber such as used by Bosch.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
This is why we love TM...just as I was looking for new blades and would have gone down the Land Rover blades route.
Car Builder Solutions is a very useful catalogue to have and browse.
Thanks Cooperman.
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
Westfield offer a similar sprung blade in black. Although I have the plain Caterham ones, which work fine given stronger arm spring, these should fit at 204mm in length. ![[Linked Image]](https://parts.westfield-sportscars.co.uk/image/cache/catalog/New%20Webshop%20images%20V3/wiper%20blade%20bk-pic109-700x700-800x800.jpg)
