Morgan Aero 8
3 members (Topline123, TalkMorgan, Image), 252 guests, and 55 robots.
Posts837,252
deano Offline OP
Just noticed my high beam warning light is not working. The lights are working perfectly and no other faults are apparent. Looking behind the dash it appears to be an electronic module ie. No bulb to replace.
Has anyone else experienced this problem?
Martin (Deano)
I took my dash apart a while ago Deano to get a live feed for a map light it frightened me so much i screwed it back quick....
...,,,Em aerotaff.
Formerly known as Aldermog
Martin, yes, mine slowly failed, followed by the ABS and EBD lights. All the lights are part of a module. Williams changed it for me, from memory the new module was less than £100, which I felt was cheap for a Morgan electronics module!!!
After replacing it I noticed that the main beam warning light stays lit for a few seconds as part of the pre-start lights check.
deano Offline OP
Thanks Peter
I might take the module out myself and see if its repairable.
Martin (Deano)
Peter - same with my hi beam light on start up.
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
deano Offline OP
Quick update guys:
So it quite a job to get the circuit board out, but once out I did a quick check with a multimeter only to find no faults. So I re-soldered the joints either side of the LED and re-tested. Works perfectly, so nothing more than a dry joint.
All back together now and every thing back to normal.
Martin (Deano)
