5 members (RichardV6, IcePack, Alan Patterson, howard, Rex_tulips), 273 guests, and 28 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,331
Members9,215
Page 3 of 5 1 2 3 4 5
I can't imagine a weeping seal, or even a really leaking one increasing oil temp.
With only 500 miles on the car the weep could be caused by combustion blow-by as the rings may not be fully run in yet. The orifice in the intake where the vent hose from the crankcase attaches is only .1" according to the S&S manual, so the vacuum 'seen' by the crankcase is limited, and excessive blow-by could exceed the negative pressure provided by the crankcase vent and seek an alternative path out of the engine.
I would keep the area clean and check it every few hundred miles, and likely it will diminish as the miles build. If it's getting worse by about 2k miles, then I'd take it up with the dealer or MMC.
Late 2012 M3W
I hope you are correct. I will clean it thoroughly before the next long (150 mile) drive.
mine has weeped since day one!! 3 new seal's fitted still weeps after 10,000miles just clean it off every service....
WOW! How many cam drive belts have you changed?
Oil only a small weep doesn’t go on the belt ! Makes the back plate slightly oily.
Mine weeped for a time with drips on the floor but seemed to fix itself.
Mine has been bone dry from day 1, but since having the cams replaced and a new timing belt it has starred to weep. Not by much but enough to leave an oily film on the garage floor and under the engine.
I
I
Could this be related to wet-sumping when the vehicle is standing for long periods?
M3W Brooklands (2015)
Moody 41 (2013)
Mine start weeping immediately when I drive it. Wipe the underside of the vehicle clean and before 10 miles is reached it has oil on it and will drop oil within 5 minutes of exiting the vehicle.
That's an interesting thought, IMHO, and could very well be. The X-wedge moves a lot of air internally as those huge pistons move up and down, and if the sump had a bunch of oil in it the available air volume could be reduced sufficiently to raise crankcase pressure during the few seconds it takes for the scavenge pump to clear the sump.
Late 2012 M3W
