8 members (High Hamster, vincentvg, piquet, IcePack, DJC, Craig Jezz, Cat302, DaveK),
370
40
Topics49,838
Posts837,295
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
My stalk broke up being held on by only the wire from the button. Cheesy piece of ....
I see the part number and was wondering if there are better replacements that would fit. Anybody?
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
mine broke last year! they are crap!!! changed under warranty... the new one worked much smoother and lighter feel to it... i was told they cost £100. they like a computer game joy stick, made of 4 micro switches, giving a momentary signal to the control unit..
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
Same here - it just fell off without being touched (sheared internally). It is being replaced under warranty thanks to the good offices of Melvyn Rutter.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Sounds like a momentary toggle switch With a left right and center off on the dash would be better. I believe my A.H. Sprite had a similar switch but was not momentary.
Posts: 902 |
nice old fashioned switch John! not momentary and dose not do headlamp main & dip and flash
Hey skullmog, do you remember the push button foot switches to dip the headlamps? There is always a way unless the darned ecu gets involved.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I think you will find the Turn Signal Module, another little black box, will get involved. That's probably equally as bad as the ECU being involved  .
Yet another nanny to take away the drivers responsibility. Just wait, some wingnut will advocate for airbags in the 3 Wheeler. Where is that little black box located for the turn signal indicator?
![[Linked Image]](https://www.tm-img.com/images/2019/08/18/Air-Bag.md.jpg) I saw this a few years ago On the MTWC stand at TOTH. The module is just below and forward of the ECU, under the fuse box.
