2 members (TBM, Ian Wegg), 249 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#591011 21/08/19 12:51 PM
ADM3W Offline OP
Hi fellow Morgan owners. I am a new M3W owner in Australia. I took delivery of the M3W in January 2019. I have had an ongoing problem with leaking oil onto the garage floor from the bevel box. the seal has been replaced twice and now the who bevel box has been replace. unfortunately, after a longer drive, say 100 to 150 miles it still leaked a little oil onto the floor. Has anyone had this persistent problem and do you have any ideas? Should the drive shaft be changed? there is nothing else? Andrew
ADM3W #591021 21/08/19 01:38 PM
You might want to look at this and associated posts in the Three Wheeler Forum
http://www.talkmorgan.com/ubbthreads.php/topics/569089/a-reason-why-m3ws-leak-oil#Post569089
ADM3W #591084 21/08/19 07:23 PM
If the bevel box is overfilled with oil it can cause the oil seal to leak, it should only be filled through the filler plug on the rear of the bevel box and not through the orange breather cap which is higher up on the RH side.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
