Topics49,859
Posts837,479
Posts: 5 |
Hi fellow Morgan owners. I am a new M3W owner in Australia. I took delivery of the M3W in January 2019. I have had an ongoing problem with leaking oil onto the garage floor from the bevel box. the seal has been replaced twice and now the who bevel box has been replace. unfortunately, after a longer drive, say 100 to 150 miles it still leaked a little oil onto the floor. Has anyone had this persistent problem and do you have any ideas? Should the drive shaft be changed? there is nothing else? Andrew
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Hi fellow Morgan owners. I am a new M3W owner in Australia. I took delivery of the M3W in January 2019. I have had an ongoing problem with leaking oil onto the garage floor from the bevel box. the seal has been replaced twice and now the who bevel box has been replace. unfortunately, after a longer drive, say 100 to 150 miles it still leaked a little oil onto the floor. Has anyone had this persistent problem and do you have any ideas? Should the drive shaft be changed? there is nothing else? Andrew If the bevel box is overfilled with oil it can cause the oil seal to leak, it should only be filled through the filler plug on the rear of the bevel box and not through the orange breather cap which is higher up on the RH side.
