4 members (+8Rich, CJB, Winigo, MATTMOG), 248 guests, and 64 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,629
Moggo
nano2nd Offline OP
A friend has a 68 Plus 4 and he says it idles poorly and sometimes stalls when the engine is warmed up. He says that the temperature gauge reads normal when this happens. The engine has a pair of SU H6 carbs. I've got a little experience with the SU carbs on my 52MG TD. Does anyone have any suggestions about where to start?
Thanks in advance,
Gareth Parfitt
Hi Gareth. It might be really useful if your friend joined this forum. Can’t help him myself unfortunately.
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
You could take a look where the fuel line runs..... the fuel line can get too hot and the fuel will slightly evaporate ... a fix (bodge) would be to wrap the line in bacon foil and see if that makes any difference. If it does, then a better solution will be possible.
+8 4.8
it might be worth checking/changing the condenser (capacitor) these often fail when the engine gets hot.
David Byrne
On a Morgan of that age there are so many possibilities, though when hot if the choke is pulled out a little and slowly listening to the revs to detect if there is any improvement. if there is then perhaps the mixture may be too weak which then could be down to air leakage at the manifold or carbs.. ?
Good luck, do come back and let us know what you have tried and the results if any obtained..
Carbs need to be balanced etc...also I found a gunsons colourtune is ideal to check the mixture is right
Our 1956 plus 4 TR engine purrs ...
pm me and ill give you my phone number for your friend...will try to assist.
Triumph Herald 1969 13/60
Morris 1970
There are only a couple of things to check. Before starting diagnostics, make sure that basic routine tune up has been done.
Check the ignition system. Your problem is most likely the coil or the condenser. Unless they're new I would probably just replace both.
'61 +4 DHC
'70 4/4
'80 4/4 4seater
