1 members (Pittsartist), 313 guests, and 46 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 7 of 9 1 2 3 4 5 6 7 8 9
He just looks at the pictures Chris
Originally Posted by Ricardo
Good gracious me! We’ve made it into the Daily Mail (well, I have) .....
https://www.dailymail.co.uk/news/ar...pper-moustachioed-motorcyclist-road.html
hide
You’re famous!
Looking very dapper!
Too true, and then only pictures of me 🐌
Some pics from the Brooklands ride:
And Brooklands have a short video on their Facebook page:
https://www.facebook.com/BrooklandsMembers/videos/748273995623039/
Red Leader drive
Charlotte North Carolina.... had a record HOT day
Bolt backed out on my right headlamp mount and it pivoted downward....
Rodger
2004 Plus 8 (wife's)
You’re famous!
👍[/quote]
Thanks Shaun, what an excellent appreciation of style you have sir sherlock
Oops! Check out these guys, you might like them: http://www.talkmorgan.com/ubbthreads.php/topics/544396/alternative-turn-signals#Post544396
What were your impressions of the 'new' 3 Wheeler Chris? [Ignoring the Duracel colour of course...]
Andy
That's Bentley Flame Orange I'll have you know...….
This is a SVA Euro3 with MMC Stage 1 exhaust/air filter but otherwise I believe it to be mechanically standard. It's done 750 miles as compared to 30.5k (and nearly 6 years) on mine.
It felt a bit more solid and had a smoother transmission (I know mine is quite bad and needs the clutch/compensator looking at).
On initial pull away the throttle was more sensitive than mine and the steering a bit lighter. I was pleasantly surprised by the Brooklands steering wheel which felt really good to use.
On the slightly damp to wet roads, even at relatively low speeds the Avon front tyres didn't feel as precise as the Blockleys. However this might be affected by tyre pressure as I found the Avons benefit from being run at 28-30psi
In the mid and towards the upper end of the revs/speed it did run out of puff a bit compared to mine which has the stage 2/3 high lift cams.
The stock Spax shocks are not as good as the Spax adjustables being harsher over speedbumps - not excessively so but enough to notice the difference.
Overall it's a cracking example of a M3W and shows the car has subtly evolved over the last 5-6 years.
Red Leader drive
I could smell something as I pulled into Charlotte, but thought it might be the new asphalt (De Nile is a river in Egypt)…. but when I pulled off the freeway right handed smoke made it clear it was not. Turns out the top bolt was a little too short to engage the plastic on the lock nut..... my bad!
Should I take bets on who can name the tartan first?
Rodger
