Topics49,846
Posts837,384
Posts: 1,562 |
I really like that - for the less skilled amongst us , one for Garage56 etc?
Posts: 874 Likes: 156
Posts: 874 Likes: 156 |
First adaptation of the piece : ![[Linked Image]](https://zupimages.net/up/19/40/a6il.jpg) ![[Linked Image]](https://zupimages.net/up/19/40/cole.jpg)
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
The holes are finished. there are other cuts to make + adjust the piece to the English wheel : ![[Linked Image]](https://zupimages.net/up/19/40/8vo7.jpg) ![[Linked Image]](https://zupimages.net/up/19/40/pruy.jpg)
Posts: 1,562 |
Nice job. Have you considered using an edge trim to protect things from the sharp edges, something like this https://www.holden.co.uk/p/edge_trim_pvc_8m1 Not sure how flexible it is to go round the corners though - a little heat might persuade it. Also, is that the armrest from your car now attached to the cover, or did you obtain a spare?
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Beautiful work👍 Do the louvres relieve pressure or are the cosmetic?
What holds it in place at speed?
Hi Nippymog, I thought about sticking an EPDM rubber band under the barrel cover and not on the edge For the armrest, I will move it according to the use, either on the car without barrel cover, or on the barrel cover .... ![[Linked Image]](https://zupimages.net/up/19/40/imbm.jpg) Lightspeed, The louvres are not decorative, they allow that there is no air pressure that is created at this place, there is no speed limit with the barrel cover
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
I wonder if you could add something like the apron they use on kayaks, to keep your bottom half and the seat, totally dry. I found over last winter, when unusually, I had my M3W in the UK over the winter after its rebuild at Malvern, that even if you have good water-proof over-trousers on, if you are sitting in a puddle of water, you still get a wet backside.
Wilson
Posts: 902 |
Nestor, how is your Pool ball gear knob attached?
