0 members (), 206 guests, and 86 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 2 of 9 1 2 3 4 5 6 7 8 9
I really like that - for the less skilled amongst us , one for Garage56 etc?
First adaptation of the piece :
Lille - France
Plus Four 2024
Lille - France
Plus Four 2024
The holes are finished. there are other cuts to make + adjust the piece to the English wheel :
Lille - France
Plus Four 2024
Nice job.
Have you considered using an edge trim to protect things from the sharp edges, something like this https://www.holden.co.uk/p/edge_trim_pvc_8m1
Not sure how flexible it is to go round the corners though - a little heat might persuade it.
Also, is that the armrest from your car now attached to the cover, or did you obtain a spare?
Beautiful work👍 Do the louvres relieve pressure or are the cosmetic?
What holds it in place at speed?
Hi Nippymog,
I thought about sticking an EPDM rubber band under the barrel cover and not on the edge
For the armrest, I will move it according to the use, either on the car without barrel cover, or on the barrel cover ....
Lightspeed,
The louvres are not decorative, they allow that there is no air pressure that is created at this place, there is no speed limit with the barrel cover
Lille - France
Plus Four 2024
Thanks Nestor.
I wonder if you could add something like the apron they use on kayaks, to keep your bottom half and the seat, totally dry. I found over last winter, when unusually, I had my M3W in the UK over the winter after its rebuild at Malvern, that even if you have good water-proof over-trousers on, if you are sitting in a puddle of water, you still get a wet backside.
Wilson
Nestor, how is your Pool ball gear knob attached?
