4 members (Graham, G4FUJ, DaveW, Chris Cosher, +8Rich), 233 guests, and 74 robots.
+8Rich 75
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,713
#597953 03/10/19 03:18 PM
Does anybody have any detailed information on topping up/changing the gear box oil on a M3W?
I did try searching the Forum but I'm new to this and couldn't find anything but I can't be the first to ask this!
Q
Q
Have a look at my “very excited” Thread.
It’s close to midway if I’m not mistaken.
I hope it helps.
Remove the boot liner.
Jack up the rear of the car and support.
Remove the drain plug in the rear face of the bevel box 24mm socket required with a short extension, if you have the NVH kit access is tight
Lower car and allow oil to drain not much comes out only about 300ml
Raise car again and refit drain plug undo filler, which is about 50mm directly above the drain plug on the rear face and requires an allen(hex) key to undo, 10mm if I remember.
Using a syringe and plastic tube fill the bevel box from above where you have removed the boot liner until oil comes out of the fill hole and refit fill plug.
Lower car
Refit boot liner
You will find threads on here recommending filling through the orange breather on the RH side of the bevel box, this is not recommended as it can lead to leaking seals.
There are lots of threads on the subject, try using google and something like "talk morgan bevel box oil change"
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Lower car
Refit boot liner
I believe the OP was talking about the transmission Gear Box) rather than the rear end (bevel box). Maybe I am incorrect and if the OP would clarify he might get what he needs. I know the transmission access is not as easy as the bevel box.
I would think an online search of Mazda Miata 5 speed gearbox oil change might yield useful results.
Late 2012 M3W
Phil Bleazey recently reported that he has had good results with 'bog standard 75/85 mineral oil as recommended by MX5ers'.
Andy
I must learn to read, the OP post does indeed say gearbox
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
well, the bevel is a gear..... cheers
Rodger
2004 Plus 8 (wife's)
True, and it is indeed in a box.
What do the Brits call a transmission? We Americans generally refer to a gearbox as a TRANSMISSION, at least on the Westcoast where I had all my automotive experience.
That'l be the gearbox, the bit in the middle.
The bit at the back can be known as: back axle, final drive or Diff. Depending on who you are talking to.
