3 members (deano, Bunny, RedThree), 293 guests, and 108 robots.
+8Rich 75
Topics49,868
Posts837,649
Moggo
Page 3 of 5 1 2 3 4 5
MOR404 #597006 27/09/19 08:26 AM
Originally Posted by MOR404
Having gone through the list as recommended we ended up taking out the carb again. On inspection we noted that the butterfly shaft moves when pushed sideways so we took it off to check about wear. We put on another plastic washer on the drivers side of the carb shaft and engine is now idling well at 900rpm and not hunting or dying on idle. Looks like the shat was leaking air.
Luddite I ve owned my Morgan for two years and it is a 1980 model with 36000 miles with a Webber twin choke carb.
Good result, if anyone's interested - you can test in-situ by carefully spraying Cold Start around joints & spindles whist the engine is running, if you've got a leak and it's drawn in the revs will rise
MOR404 #597534 30/09/19 09:35 PM
That sounds very familiar. I consider myself very much a neophyte when it comes to diagnosing such ephemeral things as a lumpy idle, but this is exactly what happened to my car a couple of years ago ('85 CVH with Weber 32/24 DFT carburettor). I went through all the usual (read: easy) stuff, changed plugs, leads, condenser... eventually a local garage who understands these things found the butterfly throttle was "loose in stays" and a tiny plastic washer was all that was needed to fix it. I'd never have dared to prod and poke around in the carb to find it myself!
Doug
1985 4/4 4str, Jubilee Blue
I saw neophyte in the Matrix.
Best Regards
Lang may yer lum reek
SCX358G #598206 05/10/19 01:50 PM
After using the car regularly over the past days I am still not happy with idling especially when I start the car the first time during the day. It still does not run at 900rpm. However after 10 minutes on the road it runs ok even on neutral. I also noted that after I switched off the car until I open the garage door after a long run, it took me three attempts to start whilst normally it starts spot on. The car runs very well after reaching the correct temperature. What should I look at next.
SCX358G #598212 05/10/19 02:37 PM
Based on your opening statement where you indicated some pinking at various times I would check the plug gaps, points and the timing in that order. Although you mention the timing is correct what is that based on, all engines are slightly different to what is written in manuals?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
SCX358G #598222 05/10/19 04:32 PM
Bruce The initial problem was stalling whilst idling not pinking.
SCX358G #598225 05/10/19 05:02 PM
MOR404, sorry to read that your Mog is not running as you might wish despite resolving your carb issue..I guess an other question is did it ever run to match your expectations of it..?
Modern cars have so much complexity built in to ensure smooth running in all sorts of situations that are far outside the capabilities of any elderly carb fed engine which may be less than comfortable while running on the choke, which it`s self may not be operating perfectly if automatically controlled..?
Your car is nearly 40 years old, it has spent a lot of time with it`s engine and much else not in use and depending on climate, corrosion can play a part, which can cause it`s own wear and tear issues thus mileage as recorded in the speedo may not be taken as a true assessment of condition. Also that you have only owned it for 2 of it`s years (?) you may have no idea as to how it has been cared for over the previous 30 or so years..and as I hinted before it is also possible the engine has been subject to some modifications..? Fuel quality and dependant on whether the engine has been modified to run on whatever fuel you use can play a part.
Perhaps a compression test may be worthwhile to help you partly assess the engine`s condition..?
SCX358G #598239 05/10/19 06:24 PM
When I start mine using the choke and put the choke in once it has started it takes about 8-10 minutes (depending on ambient temps) to warm up before it will idle correctly and will stall at idle before it has warmed. Have you tried a new coil, they can be fickle creatures? My comment above still holds, they are simple things to check and adjust and can make a difference. I also assume that the plugs colour and condition are correct?
Bruce
2013 M3W (Olga)
MOR404 #598248 05/10/19 07:54 PM
Indeed, Bruce was reading the original post by "SCX358G" Dave with the '69 +4. We haven't heard from him since, I wonder if he fixed it?
2011 Morgan 4/4
1932 Austin 7 Chummy
Paul F #598250 05/10/19 08:00 PM
Originally Posted by Paul F
I vaguely remember being told that Weber carbs fitted to Ford engines had a typical life expectancy around 40,000 miles
My 4/4 on TWIN Webers is about to clock up 39,000 miles. I've just had a look at the price of replacements. scared
2011 Morgan 4/4
