8 members (TeddyAds, Aeromax51, MOG42, GrumpyPa, sprinty, CooperMan, MJF, Image),
244
43
Topics49,843
Posts837,348
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Thanks all. That settles it for me - no tread rubbers or wing mounted sidelights.  although expensive I would go for PP Film, the 'subbies' who fit for the factory do a very good job (even did my headlamp lenses) Never thought of doing the headlamps, good idea that can be my next job š
Craig Jezz
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Thanks all. That settles it for me - no tread rubbers or wing mounted sidelights.  although expensive I would go for PP Film, the 'subbies' who fit for the factory do a very good job (even did my headlamp lenses) Tarka. came with PPF on the running boards. It scuffs easily. I had it replaced once, they need doing again. I though about I'm tempted to leave it off and use lots of polish.
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
Thanks all. That settles it for me - no tread rubbers or wing mounted sidelights.  although expensive I would go for PP Film, the 'subbies' who fit for the factory do a very good job (even did my headlamp lenses) Tarka. came with PPF on the running boards. It scuffs easily. I had it replaced once, they need doing again. I though about I'm tempted to leave it off and use lots of polish. Iām thinking along those lines as well. It looks awful when scuffed and I think it would be easier to treat the wing paintwork. Defendall is a good option for the front wings where it protects from paint chips.
David 2020 Roadster 3.7 Dove Grey.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Thanks all. That settles it for me - no tread rubbers or wing mounted sidelights.  although expensive I would go for PP Film, the 'subbies' who fit for the factory do a very good job (even did my headlamp lenses) Tarka. came with PPF on the running boards. It scuffs easily. I had it replaced once, they need doing again. I though about I'm tempted to leave it off and use lots of polish. Mine has the protection film all over the leading surfaces - and looks fine. Except for the running boards, which, despite this careful owner, have scuffs that cannot be removed. I am pondering removing or replacing - I'm not sure if the running board PP films can be purchased without a whole 'kit'.
+8 4.8
Thanks all. That settles it for me - no tread rubbers or wing mounted sidelights.  although expensive I would go for PP Film, the 'subbies' who fit for the factory do a very good job (even did my headlamp lenses) Tarka. came with PPF on the running boards. It scuffs easily. I had it replaced once, they need doing again. I though about I'm tempted to leave it off and use lots of polish. Mine has the protection film all over the leading surfaces - and looks fine. Except for the running boards, which, despite this careful owner, have scuffs that cannot be removed. I am pondering removing or replacing - I'm not sure if the running board PP films can be purchased without a whole 'kit'. I believe they can, Neil. I recall on my last Roadster I replaced the film one one wing.
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
I haven't had occasion to try it but when I bought my Morgan from Melvyn Rutter he told me Brasso removes scuffs and scratches from the PPF.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
I might try some brasso - I heard it can remove scratches from watch glass too...
+8 4.8
Posts: 8,662 Likes: 408
Posts: 8,662 Likes: 408 |
No scuffs on my running boards yet after 9000 miles. Was advised to get PPF elsewhere but shortly after received a small chip in front of wing, since touched up. As the object that caused it left a slight dent though, cannot see how PPF would have saved that ![[Linked Image]](https://www.series2club.co.uk/new_forum/Smileys/wittsends/nixweiss.gif)
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Just don't rub too hard or it gets hot and marks even more. Given that it's there to protect, I don't get too uptight about marks although my Plus 4 doesn't have any scuffs yet. My Roadster doesn't have any protection, and after 14 years, no significant scuffs on the running boards. Obviously we are not all pensioner gymnasts, but you should try to get in and out as if there's no protection. My mother adopted the practice of dragging her feet over the door threshold on the tin top until I fired a few choice words...ā¦ā¦...
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
Mine is 5 years old and has no protection on the wings. It did have a couple of chips and a light scratch but the scratch polished out with g3 compound and the chip is undetectable now done with a Chipex touch up set. If I was oerdering a new Morgan I probably would have it as the current one with no protection. It looks better and costs less.
