3 members (SwissMogFan, TBM, SCX358G), 128 guests, and 24 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,604
My normal procedure is Jenolite or Fertan, Bondaprimer, then black enamel (even used Aldli black)
Malcolm
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
This is what the real Land Rover enthusiasts recommend and use. Worth a look at the website for rustproofing and paint.
http://www.buzzweld.co.uk/
Use it straightaway though. It has very poor shelf life, after 9 months mine were unusable.
Brian
Jersey and Spain
Bob
As I have removed all my paint I have been using Fertan. I've been recommend it by a couple of people in the trade. Check out the Fertan site. Mention that you are in the Morgan club and you should get 10% off
Navy Dave
1976 Morgan 4/4
Like any painting the most important thing is preparation. I Use a wire brush on a drill, angle grinder or Dremel depending upon location. I then use Jenolite if any signs of rust remain. I then use thinners to clean followed by an acid etch primer such as U pol or Halfrauds do their own.
I used different types of paint depending on location. Plasticote, Hammerite or most branded paints are good.In some areas I use stonechip paint which can be painted over.
Rob
IvorMog Offline OP
Thanks for all the input.
Looks like my initial Hammerite thoughts have gone out of the window.
I've got a few days before I start so I'll do a bit more research on the suggestions and then get the elbow grease out for the cleaning and preparation.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Bob, a few years ago I used satin black engine paint to tidy up lots of exposed bits on the old MTW, I didn't want to go overboard with prep & remove patina
I've been surprised how well it's lasted considering how exposed some of the parts are, if this link works it was this
https://www.granvilleoil.com/prodInfo?pID=252
Unfortunately there are loads of 'one hit' products out there, all with the best of intentions I'm sure. But in my experience Jenolite always worked, but is now superseded by Fertan, a simple produce that does the job as long as you follow the instructions, ie, apply to a wet surface.
No connection with the producers, just a satisfied customer.
+ 1 for FERTAN.
A friend used it for a frame of Restauration for a BMW Dixie an a Ford A (1939 I think) convertible (15 years ago). He is still verry happy with the result
Another vote for Jenolite. I used it back in the '60's by the gallon and I think it is still good stuff. Hamerite is also very good after a good wire brushing, I have used it on the suspension parts of my Beetle to good effect.
Reg
