2 members (Stephen888, nick w),
224
81
Topics49,871
Posts837,679
Posts: 45 Likes: 3
Posts: 45 Likes: 3 |
We had a friend with an Aero arrive here a couple of years back and it turned out that a seemingly good battery was going flat overnight however if he operated the inertia kill switch, thereby disconnecting the battery, it would start without problems the next morning. We went to the local auto electrician and discovered two things: 1) there was a constant drain on the battery that was enough to flatten any battery overnight, and 2) the battery was a little down on power and needed replacing. It was too difficult to identify the source of the drain but when the battery was replaced the current drain dropped back to virtually normal for the various small items that had to remain live to some degree, central locking, radio, etc. So it seems that if the battery is not fully up to the correct voltage some item in the car was not fully disconnecting when the ignition was turn off. With a fully charged battery the item turned off correctly.  This friend it was me .... Chanteclair Has the Plus 6 arrived yet Not yet Ihope on December the 1 th
Posts: 45 Likes: 3
We had a friend with an Aero arrive here a couple of years back and it turned out that a seemingly good battery was going flat overnight however if he operated the inertia kill switch, thereby disconnecting the battery, it would start without problems the next morning. We went to the local auto electrician and discovered two things: 1) there was a constant drain on the battery that was enough to flatten any battery overnight, and 2) the battery was a little down on power and needed replacing. It was too difficult to identify the source of the drain but when the battery was replaced the current drain dropped back to virtually normal for the various small items that had to remain live to some degree, central locking, radio, etc. So it seems that if the battery is not fully up to the correct voltage some item in the car was not fully disconnecting when the ignition was turn off. With a fully charged battery the item turned off correctly.  This friend it was me .... Chanteclair Has the Plus 6 arrived yet Not yet, I hope December the 1 th
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Peter would you like me to come around with my FLIR camera and see what is hot! It'll be the various instrumentation adaption modules along with the Immobilizer, you'll probably find a hot CANBUS or LINBUS chip or two.
Alternately remove the fuses and see when it stops then investigate what is hanging off the end of said feed.
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
Mark, that's a smart idea. May I ask what you are using for the FLIR ? Is it s bolt to a smart phone or some dedicated device.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I'd say Yes, if I had a car. But it is still at Williams.... Should be back on Tuesday...... perhaps....
Mark, that's a smart idea. May I ask what you are using for the FLIR ? Is it s bolt to a smart phone or some dedicated device. Just the FLIR one add-on for my phone Last thing I used it for was searching for a wasp nest at night in the hedge at the bottom of my garden!
Give me a shout when it's convenient Peter, maybe one weekend.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Mark, that's a smart idea. May I ask what you are using for the FLIR ? Is it s bolt to a smart phone or some dedicated device. Just the FLIR one add-on for my phone Last thing I used it for was searching for a wasp nest at night in the hedge at the bottom of my garden! Info at https://www.flir.com/flirone
