5 members (SteveT, Strathaven, cerealsurfer, MartinB60, Hamwich), 266 guests, and 98 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
Page 5 of 8 1 2 3 4 5 6 7 8
Ricardo #601811 31/10/19 11:03 PM
Originally Posted by Ricardo
Originally Posted by Dab of oppo
I think a pair of new front boots wouldn't go a miss either
You are correct Lee, only just legal, so some new Blockleys will be fitted before not too long thumbs
Think that’s an optimistic analysis, Ricardo.
You could stand as an MP in the upcoming election......
Ricardo #601914 01/11/19 07:33 PM
Impressive exhausts Ricardo. If they sound half as good as they look they will be a good buy. I must admit, I also looked at the tyres more than the exhausts in the photo wink. Not going to try a set of Michelin Commander II for the full "racy M3W" image then?
nippymog #601928 01/11/19 10:34 PM
Originally Posted by nippymog
At that point I added the roller rocker upgrade and found it worthwhile.
So you have exhaust and roller rockers and no high lift cams? Were the rockers a noticeable upgrade.?
Ricardo #601931 01/11/19 10:54 PM
I have fitted high lift cams, part of Morgan stage 2 upgrade, type 968 from memory.
The roller rockers were a distinct upgrade after this.
Ricardo #601935 01/11/19 11:26 PM
The MMC Stage 2 is cams, throttle bodies and an ECU reflash; the KH equivalent offers combinations of larger headers, rockers, cams, injectors and throttle bodies plus custom tuning; G56 is cams.
Ricardo #601941 02/11/19 01:16 AM
Thanks guys👍
Ricardo #601942 02/11/19 01:43 AM
After speaking with Stuart at Krazyhorse, i was surprised when he said that the larger throttle bodies made no difference even on the Dyno.
They come in 52mm 58mm and 66mm.
All they do is reduce icing. So if your 3 wheeler suffers from this. It may help.
Cams i think from memory are 545 569 and 618. 618s are an interference fit. With the 618s you may need the 650 spring set because of the higher lift.
Roller rockers do not make a large difference on Stage 2 or 1 engines. Stage 3 and above get a boost from them.
Somewhere i have the S&S parts list. When i find it i`ll make it available.
Ricardo #601943 02/11/19 02:45 AM
John, the interference fit valves would sure be off my Christmas List.
Ricardo #601945 02/11/19 02:55 AM
Maybe i should have said that the 618s are not a non-interference, drop the cam belt drop the pistons.
Not my experience on both counts
