0 members (), 306 guests, and 86 robots.
+8Rich 81
Topics49,849
Posts837,424
You should be able to pry the locking tab loose with a small screwdriver then remove with a pair of pliers.
Red Leader drive
I was able to pry them loose with a small driver as well
I know there are some of these clips in the fuel tank area that folk have changed - is this as a result of leaks or just preventative?
sometimes you can get a screwdriver under one of the ends...
opps, see that has been suggested
Rodger
2004 Plus 8 (wife's)
I gave up, sawed through the hose and pulled the hose off. This is the crossover fuel line between the jugs. I’ll let you all know if the smell has vanished as soon as I drive her again.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
