4 members (Sir Percival, Clipper, Zach, +8Rich), 342 guests, and 69 robots.
+8Rich 86
Topics49,851
Posts837,442
#605800 01/12/19 02:10 PM
Weird... getting a gas smell but no evidence at all of leaking. It seems to be coming from the fuel hose area between the jugs but everything LOOKS perfect! Thoughts?
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Hose between cylinders , warning for the windscreen
Add some UV dye into your fuel and inspect all hoses under the plastic cowl after a run.
Ken, have you ever replaced the hose clamps that others have mentioned were leaking?
Kankel, UV dye? What does that do to the rest of the fuel system?
That's a neat trick thumbs
Nothing, you can buy oil/fuel safe UV dye and then see all leaks using black light.
If you still have any crimped on fuel hose clamps on the engine then they should be replace with screw type fuel hose clamps, not Jubilee clips. The crimped clips are notorious for leaking and should be replaced on any part of the M3W, there are some around the fuel filter and pump as well. If that turns out not to be the problem, check the fuel tanks out, particularly around the attachment brackets and the filler tube to RH tank weld.
Thanks to everybody.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Seems those crimped clamps don’t easily “uncrimp” ( been trying for 1/2 hour). Just cut the hose and pull off?
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Maybe a Dremel tool with a cutoff wheel?
