Topics49,851
Posts837,442
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
You should be able to pry the locking tab loose with a small screwdriver then remove with a pair of pliers.
Red Leader
Posts: 1,562 |
You should be able to pry the locking tab loose with a small screwdriver then remove with a pair of pliers. I was able to pry them loose with a small driver as well I know there are some of these clips in the fuel tank area that folk have changed - is this as a result of leaks or just preventative?
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
sometimes you can get a screwdriver under one of the ends...
opps, see that has been suggested
Posts: 1,490 |
I gave up, sawed through the hose and pulled the hose off. This is the crossover fuel line between the jugs. I’ll let you all know if the smell has vanished as soon as I drive her again.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
