1 members (MOGDave),
242
32
Topics49,844
Posts837,360
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
I'd suggest looking at some of the other 3 wheeler kits. I quite like the Pembleton for example! But otherwise good luck!
Posts: 74 |
You plan to use the shaft drive (Paralever) from the donor BMW. Any reason why you are not using the BMW bevel box rather than constructing a transfer box? Intriguing project...I’m really looking forward to seeing some progress photos in time! This is the correct answer; John. If he is using the MX5 gearbox he needs to shift the output to one side to line up with the rear bevel drive. An easier option may be to use the BMW box but then you don't have a reverse gear. Some of the trike people use an electric motor for reverse and there is also a little reverse drive box available. John, Thanks for posting the pics!
Posts: 74 |
Posts: 74 |
I'd suggest looking at some of the other 3 wheeler kits. I quite like the Pembleton for example! But otherwise good luck! I have looked at the Pembleton as well as many others. I can't stand the ones that someone just hacked the front off a bike and put a pair of wheels and seat on it. I love the look of the Pembleton but it uses FWD and a VW transaxle and just about all the other ones I have seen (that utilize a Motorcycle engine) are using the bikes transmission and either no reverse or some add on system. I wanted a true 5 speed and a robust drive line. It will take more effort initially but I feel it will be worth it in the end.
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
That is quite a project . Good luck.
Posts: 74 |
Here is where I am at on basic vehicle dimensions and drive train layout. ![[Linked Image]](https://www.tm-img.com/images/2019/11/21/VEHICLE-DIMENSIONS-IN-PROGRESS.jpg)
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
This is an amazing project which I shall follow with interest, best of luck with it.
Posts: 74 |
Posts: 318 |
Hi Rob. Do you think the Paralever housing is strong enough for your project.In the sidecar world not everybody is convinced.On my BMW K1100 RS with EML Speed 2000 sidecar the Paralever is replaced by a steel substitude.
Rudolf
Morgan Aero8 S4 «Tango» Fisker Ocean Harley Davidson Livewire BMW R100/7 , R100R Moto Guzzi 254
Posts: 74 |
Rudolf No, I am not really concerned with the paralever housing, I have not heard of any failures of that system. where did you find an alternative? I assume the K series paralever is different from the R series.
