7 members (Moggo, sprinty, Image, BobtheTrain, AlyMatt, Calypso Red, MJF), 348 guests, and 92 robots.
Topics49,847
Posts837,389
Page 6 of 15 1 2 4 5 6 7 8 14 15
Rob82 Offline OP
Made some progress today. I got the top half of the transfer case milled out. There is still lots to do on it but this was the hard part. It took just under 4 hrs of machine run time to change the cast slab to this. I have the file ready to do the bottom part tomorrow If all goes well.
Rob82 #610105 28/12/19 11:52 PM
This is amazing stuff Rob thanks for the update keep them coming. What will you fill the small voids in the casting with out of interest.
+8Rich #610106 28/12/19 11:57 PM
Rob82 Offline OP
Those will be filled with the TIG welder, I may look into using a tin based alloy as they are not structural. The filler has to be conductive so I can powdercoat it if I want to. The better I get at casting the less that will happen as well.
Rob82 #610108 29/12/19 12:05 AM
Thank you for the explanation.
Rob82 #610120 29/12/19 08:02 AM
Great thread.
Following with interest. smile
Rob82 #610125 29/12/19 09:00 AM
+1.Great stuff
Rob82 #610220 29/12/19 10:33 PM
Rob82 Offline OP
I managed to get the bottom half of the transfer case milled today. Did a test fit and it looks good so far. I now have a bucket of aluminum chips that can be re-melted into the next part lol. Now it's back to the lathe to make the extensions so I can weld them on. The hardest part of the transfer case build is over now.
Rob82 #610224 29/12/19 11:20 PM
Great progress thanks again for the update, you have a lot of us hooked on your project.
Rob82 #610275 30/12/19 02:31 PM
I am glad someone posted the link to this thread in the three wheeler section as I did not know it was here. Agree with all the comments. Very impressive and keep the updates flowing.
What part of PA do you live in? I took my Morgan around the state in the fall with my dad on his Harley. Lots of great roads and things to check out.
2017 M3W Sport Green
2Sharp #610328 30/12/19 09:41 PM
Rob82 Offline OP
I am south west of Pittsburgh. Lots of great rides in my area.
