4 members (John Winn, Paul F, mph, Robbie), 212 guests, and 83 robots.
+8Rich 78
Topics49,871
Posts837,677
Rudolf
britmog Offline OP
Cheers Richard
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
And the engine should be fully warmed up.
Sometimes I'll do a compression test with the engine stone cold and then one with the engine fully warmed up and then compare the results. Diagnosed a cracked piston this way.
Arwyn
On this subject of compression testing...A question for anyone with thermo-dynamics expertise...Atmospheric pressure is about 14.6psi. So if I have an engine with 10:1 compression, in theory, the maximum cylinder pressure with no losses through valves etc would be 14.6 x 10=146psi. In practice, at BDC, the inlet valve is still open and the pressure in the cylinder is probably below atmospheric, so on the upward compression stroke, by the time the inlet valve closes there is even less swept volume to compress, which would result in something even lower than 146psi. So why do we achieve readings of 170psi upwards?
Is it something to do with heating of the trapped air under compression?
Simple explanations welcomed please.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Yes the air is compressed & heats up & thus expands
