Topics49,871
Posts837,679
Posts: 20 |
Hi all. My second posted question to this forum on my second day as a member. I have have measured the dT in the radiator and found that it is only approx 6 degree C. Working temp is from 100 down to 94. I think that is a little bit high. Or????Please advise if this is normal or.
Plus 8 BRG RHD 1996 Husqarna Novolette 1955
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Can't answer the question I'm afraid. You may get a better (faster?) answer if you post the query in the tech. section?  I'd be interested to know the answer for future reference...  Cheers,
Posts: 28 |
Hello there. Just read your question.Just had a look what my Duratec 4/4 radiator temp DT is while it is hot. 5 degrees C across mine. The temp is lower than your car. 89 C top and 84 C out. Hope this is some help. Trodnik
Posts: 20 |
Hi Trodnik
I opened this string at the wrong section. Sorry for that.
Short answer: The V8 runs hot. That seems to be the answer. If you want to have the longer answer, see the tech section under "Cooling problem"
