5 members (Chris Cosher, Grumpy2, DazMog, JohnHarris, Hamwich), 256 guests, and 78 robots.
+8Rich 77
Topics49,870
Posts837,669
Rudolf
#61240 05/05/11 04:36 AM
Hi all. My second posted question to this forum on my second day as a member.
I have have measured the dT in the radiator and found that it is only approx 6 degree C.
Working temp is from 100 down to 94. I think that is a little bit high. Or????Please advise if this is normal or.
Plus 8 BRG RHD 1996
Husqarna Novolette 1955
Mr Magoo #61243 05/05/11 06:19 AM
Can't answer the question I'm afraid.
You may get a better (faster?) answer if you post the query in the tech. section? thumbs
I'd be interested to know the answer for future reference... smile
Cheers,
Hello there.
Just read your question.Just had a look what my Duratec 4/4 radiator temp DT is while it is hot. 5 degrees C across mine. The temp is lower than your car. 89 C top and 84 C out.
Hope this is some help.
Trodnik
trodnik #61390 06/05/11 06:40 PM
Hi Trodnik
I opened this string at the wrong section. Sorry for that.
Short answer: The V8 runs hot. That seems to be the answer.
If you want to have the longer answer, see the tech section under "Cooling problem"
Plus 8 BRG RHD 1996
