3 members (Carbuilder, JoeSpeetjens, uvk33n), 297 guests, and 33 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,083
#613991 25/01/20 10:19 PM
David_E Offline OP
I managed to knock off two wiper end caps while cleaning the car today. I found one amongst the gravel but decided it was time to come up with something better. Here is my second attempt compared to the standard item. The idea was to make them longer so they didn't twist off so easily. I'll see how they stay on and I may make the end less domed.
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
David_E #613999 25/01/20 11:23 PM
Ray Offline
Coincidence. Fitted new cut downl landrover blades today. Have lost five out of six ends. Hope you have a more permanent answer....Looking forward to your solution.
David_E #614004 26/01/20 06:41 AM
X
X
I also look forward for your construction or idea.
In the moment I'm lucky only lost the half of the caps, and no risk to loose more in cause my Morgan is in hipernation.
René
2018 plus4 (sports green)
David_E #614005 26/01/20 06:50 AM
X
X
Just written the words, but than I've got an idea.
Shimano uses for some brakepads (on rimbrakes) really small splines. 1mm or less. Usuall it's for the toprange parts like
DuraAce or something of the top v-brakes.
May it's possible to drill small holes in the caps (and matching holes) in the wipers. Than you can carefully secure the
caps.
René
David_E #614039 26/01/20 12:31 PM
I cut down Europaspares 10" blades and just file the ends round and smooth.
David_E #614063 26/01/20 03:15 PM
I've used black Sugru mouldable rubber with great success.
https://sugru.com/buy/original-form...9jseh5wIVh7HtCh3D3AkSEAQYAiABEgLBpvD_BwE
David_E #614116 26/01/20 08:14 PM
What is the point of the caps? If the wiper blade touches only the glass of the front screen, I cannot see any benefit from them. If they touch the frame of the screen or even the scuttle it is another story, but they shouldn't do just that. Then the wiper blade must be too long or the sweeping angle too wide. Both can be fixed. Look up this thread for further discussion on wipers: http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/609867/Searchpage/1/Main/37095/Words/%2Balternative+%2Bwipers/Search/true/re-alternative-wipers#Post609867
Robbie the Norseman
2004 V6 Roadster
Sherwood green
David_E #614125 26/01/20 09:02 PM
Robbie,
sharp edges are prohibited
Stefan
David_E #614126 26/01/20 09:30 PM
"sharp edges are prohibited"..... banghead
Bert & B1800
stefan s #614128 26/01/20 09:59 PM
Originally Posted by stefan s
Robbie,
Stefan
I maintain what I wrote in my former post. I have so-called sharp edges, no harm done neither on my car or any other Mog I have seen without caps - and that is quite a few.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
