2 members (JMcL, Clipper),
307
Topics49,904
Posts838,082
Posts: 396 Likes: 12
Posts: 396 Likes: 12 |
I managed to knock off two wiper end caps while cleaning the car today. I found one amongst the gravel but decided it was time to come up with something better. Here is my second attempt compared to the standard item. The idea was to make them longer so they didn't twist off so easily. I'll see how they stay on and I may make the end less domed. ![[Linked Image]](https://www.tm-img.com/images/2020/01/25/DEE7A5CF-7722-4298-AFB9-6CAA2343A26D.jpg)
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Coincidence. Fitted new cut downl landrover blades today. Have lost five out of six ends. Hope you have a more permanent answer....Looking forward to your solution.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
I also look forward for your construction or idea.
In the moment I'm lucky only lost the half of the caps, and no risk to loose more in cause my Morgan is in hipernation.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Just written the words, but than I've got an idea.
Shimano uses for some brakepads (on rimbrakes) really small splines. 1mm or less. Usuall it's for the toprange parts like DuraAce or something of the top v-brakes.
May it's possible to drill small holes in the caps (and matching holes) in the wipers. Than you can carefully secure the caps.
René
Posts: 2,583 |
I cut down Europaspares 10" blades and just file the ends round and smooth.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
What is the point of the caps? If the wiper blade touches only the glass of the front screen, I cannot see any benefit from them. If they touch the frame of the screen or even the scuttle it is another story, but they shouldn't do just that. Then the wiper blade must be too long or the sweeping angle too wide. Both can be fixed. Look up this thread for further discussion on wipers: http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/609867/Searchpage/1/Main/37095/Words/%2Balternative+%2Bwipers/Search/true/re-alternative-wipers#Post609867
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 934 Likes: 12
Posts: 934 Likes: 12 |
Robbie, sharp edges are prohibited
Stefan
Posts: 881 Likes: 31
Posts: 881 Likes: 31 |
"sharp edges are prohibited".....
Bert & B1800 "Tis well enough to know how much to know; and when to know, not to know, too much."
Posts: 504 Likes: 2
Stefan I maintain what I wrote in my former post. I have so-called sharp edges, no harm done neither on my car or any other Mog I have seen without caps - and that is quite a few.
