6 members (Tom Sayles, MATTMOG, MartinB60, JMcL, Steve3.9+8, davewhite), 160 guests, and 110 robots.
+8Rich 78
Topics49,872
Posts837,689
Rudolf
#61304 05/05/11 07:21 PM
Have anyone the dim on the kingpin and the bush?
Have understund its a 1" preferably hard chrome rod but I can not find the thread size and the total lenght on the rod.
And I also wounder about the bush size? It outer dim.
Plus 8 BRG RHD 1996
Husqarna Novolette 1955
Mr Magoo #61313 05/05/11 08:02 PM
I can measure my old bushes tomorrow.
Hard chrome pins come with new nuts. The thread is UNF, probably half inch from memory, but could be 7/16".
DaveW #61391 06/05/11 07:36 PM
I sent my old pins to the scrapyard at easter so too late to measure the length. The diameter is 1". The thread on the lower end is 7/16"UNF. There is also a tapped hole in the top, but I have no way of knowing now what that thread is. I recall it was a bit unusual. The bushes have an outside diameter of 1&7/32". Bear in mind though that some Mogs had nylon bushes and they were different. If you want to make your own, then it is safer to strip the old ones down and use as patterns.
DaveW #61434 07/05/11 04:46 PM
I have just measured up my old pins and bushes (not been to the scrapyard yet!).
Length of 1" dia part of kingpin - 15-1/16" (15.062"), plus -
Bottom thread (male) - 1/2"UNF (not 7/16"), 13/16" (0.812") long .
Top thread (female) - drilled 2-3/4" (2.75") deep, tapped 1/2"BSF, 2-1/2" (2.5") approx deep, and then drilled down at a smaller diameter to meet oil groove cross hole. (NB: Current factory grease-lubricated stainless pins are tapped 1/2"UNF.)
Bush length 2-1/2" (2.5")
Bush outer dia 1.225", measured with my plastic vernier gauge - I would get your old ones properly measured with a micrometer if you are thinking of making new ones yourself, as the interference fit in the stub axle is critical.
Hope this is useful
Fjemog
Fjemog
1993 Plus 8
