Topics49,843
Posts837,343
Posts: 3,727 |
Excellent Job Richard, If only I possessed such skills.
You may find, as I did that a strategically placed block of 1cm thick neoprene located under the QR Head End when in its clip will stop it rattling against some bodywork or Bonnet
Frank
Posts: 8,662 Likes: 408
Posts: 8,662 Likes: 408 |
Thanks Frank. Will bear that suggestion in mind. The plastic coated Terry clips I used, although small, grip the 6mm stays really well and placed so nothing touches any metal. The pack I bought means I have spares and easily replaceable as held on with tiny 2mm screws.
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
I have been well impressed by the ingenuity and craftmanship involved in the suggestions regarding making your own locking bonnet stays. Sadly, I feel I am not able to emulate most of these. As Inspector Harold Callahan said in Dirty Harry, "A man has to know his limitations!" However, I can cope with stuffing a safety pin ![[Linked Image]](https://www.tm-img.com/images/2020/02/10/close_up.md.jpg) through a 1.5mm hole ![[Linked Image]](https://www.tm-img.com/images/2020/02/10/rod.md.jpg) and when the wind blows, ![[Linked Image]](https://www.tm-img.com/images/2020/02/10/IMGP8369.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/02/10/IMGP8372.md.jpg) the bonnet stays safely in place! Safety pins are stored conveniently in the glove box. Job done.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Ingenious idea but a faff fitting safety pins at each end maybe. You did say you fitted at bottom of stay as well didn't you
Posts: 310 Likes: 9
That would be too much like hard work! My stays are Heart of England and are bolted in place at the bottom, as are most I expect. Only pinned at the top. I wondered about R clips at the top but I did not have any small enough.
Sorry didn't look at age of your car(s). Your pics looked to show the current ex factory "harpoons" which aren't secured at either end!
Mine will be retired to a distant corner of the garage now.
Posts: 310 Likes: 9
The bottom is standard HoEM stainless rod bent at right angles, threaded and Aerotight self locking nut. No pins needed. ![[Linked Image]](https://www.tm-img.com/images/2020/02/10/nut.md.jpg)
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
My turn! Already had stays - the kind that slotted into a small hole in the bonnet catch. Cut an M6 thread into the end, fitted a couple of the QR joints with a M6 locking nut, then made a couple of 'L' brackets out of some stainless I had lying around. Just fitted them pre 'Storm Dennis'  ![[Linked Image]](https://tm-img.com/images/2020/02/15/igwqHHM_tL3Pfg_211uNvi1vzl7ciFNHZ9coXoH1fDipEogwBUvUYuBrYd_tNi1Ps48XrvTKm0ij2HA1I4q-_hpZKFP50-CM9LyBB85ki9Ulin0ck6V8Tt4L_xS6UpOCGGUp8nHIDhrzcGUB3s7ga-FpIwX6QUv6RNcGftw_avusPISHm8VGqSn6B1SQoRAK2TbvtTyL.jpg) ![[Linked Image]](https://tm-img.com/images/2020/02/15/JgngEn_1mjBrkkT_ibmF5Aj831HxVllERxF3FFpcUylq2sqcVbQzuD1XKLuRJrTW_KlHB9WBYhzdyt-fvpPwthy3SuGw_d_rBGneWE5Og_-n3b701pYJLg2nyQfqCLe4wqs09ClRCIkVKY4UHkBD70G975Ur7WrkCaHro2PWdy-cY9D8NM4gg8AFURX2if7qYDQYRPLD.jpg)
Posts: 40 |
Try a bungee louvre to louver going between the 2 bonnet halves can have one or both sides open!
G Walker 1983 +8, 1933 singer 9 2022 MG ZS (electric)
