8 members (MOG42, CooperMan, TeddyAds, Aeromax51, GrumpyPa, sprinty, MJF, Image), 235 guests, and 44 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,348
Christoph
Page 6 of 6 1 2 3 4 5 6
RichardV6 #616296 09/02/20 03:42 PM
Green & Grown Up
Green & Grown Up
Excellent Job Richard, If only I possessed such skills.
You may find, as I did that a strategically placed block of 1cm thick neoprene located under the QR Head End when in its clip will stop it rattling against some bodywork or Bonnet
Frank
RobCol #616397 10/02/20 07:41 AM
Thanks Frank. Will bear that suggestion in mind. The plastic coated Terry clips I used, although small, grip the 6mm stays really well and placed so nothing touches any metal. The pack I bought means I have spares and easily replaceable as held on with tiny 2mm screws.
RobCol #616460 10/02/20 01:29 PM
I have been well impressed by the ingenuity and craftmanship involved in the suggestions regarding making your own locking bonnet stays. Sadly, I feel I am not able to emulate most of these.
As Inspector Harold Callahan said in Dirty Harry, "A man has to know his limitations!"
However, I can cope with stuffing a safety pin
through a 1.5mm hole
and when the wind blows,
the bonnet stays safely in place!
Safety pins are stored conveniently in the glove box. Job done.
1994 +8, BMW Calypso Red.
How do you open the boot?
RobCol #616470 10/02/20 02:30 PM
Ingenious idea but a faff fitting safety pins at each end maybe. You did say you fitted at bottom of stay as well didn't you wink hide
RichardV6 #616475 10/02/20 02:54 PM
That would be too much like hard work! My stays are Heart of England and are bolted in place at the bottom, as are most I expect. Only pinned at the top. I wondered about R clips at the top but I did not have any small enough.
RobCol #616477 10/02/20 03:09 PM
Sorry didn't look at age of your car(s). Your pics looked to show the current ex factory "harpoons" which aren't secured at either end!
Mine will be retired to a distant corner of the garage now.
RobCol #616502 10/02/20 05:01 PM
The bottom is standard HoEM stainless rod bent at right angles, threaded and Aerotight self locking nut. No pins needed.
RobCol #617421 15/02/20 02:06 PM
TBM Offline
My turn!
Already had stays - the kind that slotted into a small hole in the bonnet catch. Cut an M6 thread into the end, fitted a couple of the QR joints with a M6 locking nut, then made a couple of 'L' brackets out of some stainless I had lying around.
Just fitted them pre 'Storm Dennis' smile
RobCol #627858 03/04/20 11:06 AM
Try a bungee louvre to louver going between the 2 bonnet halves can have one or both sides open!
G Walker
1983 +8, 1933 singer 9 2022 MG ZS (electric)
