6 members (SEG, MJF, JMcL, BobtheTrain, Zach, MartO), 213 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,902
Posts838,049
Page 2 of 6 1 2 3 4 5 6
The Centa rollers wouldn't stop the engine firing.
The cranking didn't sound too bad to me but could be explained by a broken cambelt leaving a valve open on each cylinder.
Red Leader drive
Went back and had another listen - I agree with the cam belt thought... just doesn't sound right when cranking, certainly not like a no-spark or no-fuel cranking sound.
If the Centa rollers have gone then the starter motor will only turn the ring gear/clutch/inner Centa assy - i.e. the engine won't turn over. I've never heard this in person but I guess the sound would be a much faster spinning type sound than in the video (stop me if I'm being too technical hide) so I like the broken cambelt scenario you offer. thumbs
Andy
And all of the above assumes that they checked the inertia cut off and that they hadn't run out of fuel.......
Red Leader drive
Fuel pump
Change fuel filter to
I repaired 3 Mtw this year with the same issue
Thats an interesting point I hadn't paid too much attention as to where the starter motor and ring gear are situated, but as you say it is engine, compensator, flywheel/clutch/ring gear/starter motor and then the gearbox.
So if the compensator fails then the engine won't start as there is no connection through to the ring gear/starter motor. If the engine was running when they lost drive and stopped and now won't start after they turned it off that does indeed point to compensator failure, if however the engine cut out when driving then cambelt or fuel pump.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
They would have been really unlucky to have all 4 Centa rollers fail at once.
Red Leader drive
They don't all fail at once I reckon. One goes, then another, then another then one roller is doing all the work so it's game over pretty soon after! Several people have had this happen over the past 18 months or so on new cars. Conclusion is that there was a bad batch of rollers that made it into production.
Andy
Just seen the video and since it sounds like it is spinning over very fast and easily on the starter so I too will take a guess at a broken cambelt and hopefully not anything else broken on the cams or pinion end of the crank that would keep some valves open while the engine spins.
Always a bit of a risk saying there is nothing wrong with the bevel box or the compensator but in this case it won't have anything to do with the engine not starting. Very much hoping it is just the cambelt, that the breakage is just a bad luck special and not to do with a sticking valve or such-like and that a spare is nearby (the alignment dowels are 3/16" so reversed drill bits are fairly ideal replacements for dowels.)
Good luck!
I hope it's just a broken cam belt as thats an easy roadside fix, far worse is 4 mashed rollers in the Centa coupling.
