8 members (Ruut Bianchi, Themorganeer, Morganmike, BillHart, Chris Cosher, MogOnTheMove, Ubiquitous, GrumpyPa),
313
40
Topics48,362
Posts813,325
Members9,215
Posts: 365 |
Installed a new battery and my battery ran down. I noticed every now and then you hear a tick and the tachometer moves up and down. Is this normal? I assuming that is what is running the battery down when it sits.
Thanks
2017 M3W Sport Green
Posts: 1,774 Likes: 19
Posts: 1,774 Likes: 19 |
No ticking for me... 1. I use a CTEK connected to the 12v accessory port in the car. Never had a problem starting after its been on this (on original 3 yr old battery)... 2. When overnighted at RTTC twice this year and the battery failed to start the car on both occasions. I took their suggestion to check and top up the battery - found the water levels low. Carry a Lithium booster pack in case of issues on travels though...
Posts: 365 |
Thanks. Maybe just better to use a tender charger. The ticking is very odd. Very intermittent timing wise and takes about 5 minutes. It is like a pulse of electricity going through to the tack.
Posts: 296 Likes: 4
Posts: 296 Likes: 4 |
2Sharp, what model of Morgan do you have & what year is it?
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 5,366 Likes: 15
Posts: 5,366 Likes: 15 |
No ticking for me... 1. I use a CTEK connected to the 12v accessory port in the car. Never had a problem starting after its been on this (on original 3 yr old battery)... 2. When overnighted at RTTC twice this year and the battery failed to start the car on both occasions. I took their suggestion to check and top up the battery - found the water levels low. Carry a Lithium booster pack in case of issues on travels though... I will admit to this, but I thought Morgan batteries were either sealed for life, no fill or gel type. Is that wrong, if so I better get out to the garage and have a look.
Posts: 365 |
I have a 2017 Morgan 3 wheeler.
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
No ticking or flick of the tacho on my 2013 M3W. Suggest something is not quite right there. Try removing a fuse at a time to see what circuit is causing the "tick" as a start. Even with the immobiliser fitted your battery shouldn't drain in less a month, if it's in good condition.
Posts: 365 |
Well after a couple years and a dead battery a couple times I finally figured it out. I replaced the voltage regulator with the Harley version and the tick is gone.
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
Well after a couple years and a dead battery a couple times I finally figured it out. I replaced the voltage regulator with the Harley version and the tick is gone. Ahhh, yet another thing to be aware of!
Posts: 365 |
I spoke too soon. The tick is still there. I think the battery was just low. It is very odd.
