6 members (rossocorsa, ajg141, RedThree, Image, Rog G, James B W), 267 guests, and 39 robots.
+8Rich 66
John V6 64
DaveW 56
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
The Stanley Tour 2025
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Topics48,352
Posts813,172
Members9,212
Rog Offline
Originally Posted by IvorMog
On my car you can tease the switch out and test the switch connections but not sure on your model.
Unfortunately the switch will be soldered to the pcb.
A desperate long shot…. Sometimes relays can become sticky or lazy through lack of use. Start the car and take the engine up to around 1500rpm to get a healthy voltage out of the alternator to give the relay the best chance of working. Switch on headlights and then rapidly press the fog lights many times. If it is a sticky latching relay it may just come back to life.
Roger
Bad tidings? Possibly the pcb board is U/S, a well known fault. £500+ if you can get hold of one that is.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Did you test the fuse, electrically, or just look at it?
'09 Gen2 MINI Cooper ragtop
Originally Posted by Mark P
MOT due Monday and the fog light switch is illuminated but when depressed does not stay in and no rear fog light on .
Is there easy fix for limited electrical knowledge! I have a blank switch next to it that stays in when depressed ..is this a simple swop over option or any other ideas—- the stress to solve by Monday
Any help appreciated
Mark
My aircon switch stopped working - exactly the same problem... illuminated when pushed in but did not stay in.
B&C fixed it by removing the switch and cleaning it. Works fine now.
+8 4.8
Mark P Offline OP
Yes fuse checked with meter
Never seen in non green
thumbs
Mark P Offline OP
One other thought —- could l solve this issue differently by putting new wiring loom, switch ,fuse etc in that is independent
of the fault wherever it is ie a dedicated one off switch and power from battery direct etc for the fog lamp.
Surely that would be legal for the mot ?
yes, you could do this but switch needs to have a tell tale when in the “on” position i.e. the switch itself lights up or you have a separate dash indicator light that comes on with the switch.
Doug
1958 Triton 650
Mark P Offline OP
Great thanks now an option with £30 parts
I'm only guessing but doesn't it have to be linked to the headlights on modern cars so it only comes on with the headlights and goes out when the headlight is switched off.
Only a thought, others will confirm or refute.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
