11 members (Graham, G4FUJ, High Hamster, DCH, Montegue, JamesS, MartO, Joske Vermeule, TeddyAds, sewin, cerealsurfer, BLUE+4), 307 guests, and 64 robots.
+8Rich 76
Topics49,860
Posts837,522
Jonny72
#619212 27/02/20 03:25 AM
DanT Offline OP
Does anyone have a pic where the battery cutoff switch was mounted ?
DanT #619223 27/02/20 07:32 AM
TBM Offline
I think it depends on year and model - my '72 4/4 4 seat has the switch in the tool tray between battery and windscreen wiper motor.
DanT #619227 27/02/20 07:55 AM
My '76 it was fitted to the bulkhead (firewall), driver's side above right knee (the contacts on the other side were actually in the tool tray!).
On my '93 it is more or less central on the wood bulkhead behind the seats.
DanT #619236 27/02/20 08:20 AM
My 94 & 97 cars had them as Graham said centrally on the rear bulk head. GoMog has some info.
http://www.gomog.com/allmorgan/CarBatterySizes&BatteryCutoffSwitches.html#CUT
DanT #619278 27/02/20 12:35 PM
Those cheapo battery isolator switches are the work of the devil, as suggested in GoMog article and rated at only 60 amps. Consequently I opted for superior BEP versions on my boat electrics installation.
The 701 model above is rated at 275 amps continuous and much higher for cranking - click for info. Not too expensive and readily available at most marine chandelries, there are panel and flush mount versions. Switch knob is removable for security. I use the heavy duty 702 model for domestic and bow thruster batteries though, the latter remotely controlled by master switch at the other end of the boat as the thruster has been known to blow 600 amp fuse when stalled!
DanT #619287 27/02/20 01:29 PM
You've got a bowthruster !, oh you lucky chap
Mine was the poverty spec 16ft bargepole
Girlie button or not, I wouldn't be without it. Not to say the pole doesn't help when aground though blush
