2 members (JoeSpeetjens, Ian B),
321
74
Topics49,867
Posts837,614
Posts: 10 |
Does anyone have a pic where the battery cutoff switch was mounted ?
Posts: 6,670 Likes: 436
Posts: 6,670 Likes: 436 |
I think it depends on year and model - my '72 4/4 4 seat has the switch in the tool tray between battery and windscreen wiper motor.
Posts: 28,901 Likes: 352
Posts: 28,901 Likes: 352 |
My '76 it was fitted to the bulkhead (firewall), driver's side above right knee (the contacts on the other side were actually in the tool tray!). On my '93 it is more or less central on the wood bulkhead behind the seats.
Posts: 8,680 Likes: 413
Posts: 8,680 Likes: 413 |
Those cheapo battery isolator switches are the work of the devil, as suggested in GoMog article and rated at only 60 amps. Consequently I opted for superior BEP versions on my boat electrics installation. ![[Linked Image]](https://aquafax.co.uk/media/productpage/8-90035.jpg) The 701 model above is rated at 275 amps continuous and much higher for cranking - click for info. Not too expensive and readily available at most marine chandelries, there are panel and flush mount versions. Switch knob is removable for security. I use the heavy duty 702 model for domestic and bow thruster batteries though, the latter remotely controlled by master switch at the other end of the boat as the thruster has been known to blow 600 amp fuse when stalled!
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
You've got a bowthruster !, oh you lucky chap
Mine was the poverty spec 16ft bargepole
Mine was the poverty spec 16ft bargepole Girlie button or not, I wouldn't be without it. Not to say the pole doesn't help when aground though
