9 members (Davetherave, jbk, nick w, Hamwich, John Winn, +8Rich, BobtheTrain, gazum, TalkMorgan), 366 guests, and 65 robots.
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,437
#619925 01/03/20 06:40 PM
Felix42 Offline OP
Just noticed some traces of rust on my stainless steel wire wheels at the base of the spokes where the nut is. Factory fitted on 2005 car.
Is this something to be expected (It's a Morgan, Sir they all do that)? What is the best proctective application to apply (ACF50)?
Comments gratefully accepted.
Felix42 #619939 01/03/20 08:03 PM
High salt levels will attack stainless. Yes WD40 etc should help reduce it. You can also paint it over when bright with clear varnish
Felix42 #619960 01/03/20 10:47 PM
My painted stainless steel wires. Well nearly all the spoke nuts have rusted. Popped the paint off, hence I have used black hamerite to stop the rust. Plainly the nuts are not stainless.
Felix42 #619978 02/03/20 07:40 AM
So stainless no longer means what it says , presumably because the quality of these wheels is below the standard required ?
Felix42 #619980 02/03/20 07:48 AM
Won an MWS wheel cleaning kit at a raffle recently so tried it out yesterday on front wheels. The cleaning fluid which contains a cocktail of mild acids is brushed on then rinsed off after a few minutes. A diluted protection rinse is then put on and left to dry. I must say they look brilliant now and the slight tarnishing on spokes nearest centre has gone.
Felix42 #619984 02/03/20 08:25 AM
Stainless doesn't mean rust free. stainless is particularly sensitive to chloride pin hole corrosion.
John V6 #619990 02/03/20 08:56 AM
and all stainless "rusts" when deprived of oxygen - it needs this to allow formation of clear oxide protective layer which is why polished stainless dulls a little afterwards. Noticed the corrosion on marine grade stainless boarding ladder that had shrunk fit plastic protection.
John V6 #620037 02/03/20 02:00 PM
That's why you sometimes get rust spots on cutlery in dishwashers (btw don't wash dirty car parts in it unless 'er indoors is out somestick)
TBM Offline
I got stung by that once - had a bike rear hub baking nicely in the oven, a couple of bearings in the freezer, and half my tool kit in the dishy, when she came home early.
We had a rather expensive meal out that evening.....
TBM #620053 02/03/20 03:50 PM
That sounds like one of the occasions when " I was trying to reduce the cost by doing it myself " fell at the first.
Costock, UK
Disco 5
