5 members (DickJ, Ncik P, Robbie, TBM, DCH), 367 guests, and 88 robots.
+8Rich 77
Topics49,868
Posts837,640
Moggo
#620153 03/03/20 03:29 AM
I have an issue with my left foot that bothers me with some cars that have small firm clutch pedals as with the 3 Wheeler.
There does not appear to be any way to reduce for force required to depress the clutch pedal. I am planning to go in and move the pedal box farther back anyway, so I though I would see if there are any other adjustments that can be made while I am there? Ultimately I may have to pull the pedal and have some fabrication and welding done to increase the pedal area that your foot contacts, reducing the point pressure on my foot as a last resort.
Any other thoughts? thanks
2019 M3W 110 Anniversary Black
Previous: 2005 Plus 8
E
E
I could be wrong and it will be a space issue but I remember people with a similar foot force issues using a servo to reduce the required foot force on the clutch pedal.
That was years ago on a normal car with more room to play with.
Might be worth looking at the strength of a return spring (if fitted) On the Trad 4 wheel Morgans, MMC fit a very strong return spring wound around the shaft & hooked up the pedal, considering there's one internally in the clutch master cyl, & I assume in the slave cyl, then the main diaphragm of the clutch itself it's a bit of overkill
