8 members (mph, MartinB60, Morganmike, DMC1904, DJC, Graham, G4FUJ, John V6, nick w), 293 guests, and 43 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,337
Members9,215
#621611 08/03/20 10:20 PM
TBM Offline OP
I've fitted my new wheels and 205 tyres to the back of my morgan, and it appears that the drivers side tyre sticks out about 5mm more than the passenger side.
Is there any lateral adjustment in the rear axle - it would only require a 2-3mm shift to the left to equalise it.
Would a panhard rod do it? Or do I need to fix first and then use a panhard to keep it in place?
Entirely different car I know with factory 5 link rear suspension, but my back axle was centralised to chassis using the panhard rod (the fifth link) when it was found to be out around 6mm. Problem was this put the wheel to body alignment noticeably out so a compromise was found.
Well, the axle locates on a single peg on each leaf spring. Movement is really limited. Have you checked the wing width from the inner wing panel to the lip of the arch? There is often a few mm difference. A Panhard rod shouldn't be tensioned, but if you fitted one, then slackened the axle U bolts, in theory you could use the Panhard rod adjuster to help centralise the axle , before tightening everything. But also measure various points side to side. From the chassis.
Mines the same- one finger fender to wheel gap one one side two the other.
I asked the same question when I got mine, apparently this is normal, depends where the craftsman nails the wing on 😂😂😂
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Check the mounting brackets where the rear shock is bolted to the rear brake back plate. Mine broke and then the axle can drift a little.
easiest way to check is to removes the parcel shelf and try to move the shock
2025 MG ZS EV aka Trigger
TBM Offline OP
No rear shocks - it has those Armstrong lever things, that I believe mount onto the U bolts.
