1 members (Silverlady),
287
Topics48,345
Posts813,037
Posts: 6,057 Likes: 160
Posts: 6,057 Likes: 160 |
I've fitted my new wheels and 205 tyres to the back of my morgan, and it appears that the drivers side tyre sticks out about 5mm more than the passenger side.
Is there any lateral adjustment in the rear axle - it would only require a 2-3mm shift to the left to equalise it.
Would a panhard rod do it? Or do I need to fix first and then use a panhard to keep it in place?
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 7,922 Likes: 217
Posts: 7,922 Likes: 217 |
Entirely different car I know with factory 5 link rear suspension, but my back axle was centralised to chassis using the panhard rod (the fifth link) when it was found to be out around 6mm. Problem was this put the wheel to body alignment noticeably out so a compromise was found.
Posts: 21,868 Likes: 167
Posts: 21,868 Likes: 167 |
Well, the axle locates on a single peg on each leaf spring. Movement is really limited. Have you checked the wing width from the inner wing panel to the lip of the arch? There is often a few mm difference. A Panhard rod shouldn't be tensioned, but if you fitted one, then slackened the axle U bolts, in theory you could use the Panhard rod adjuster to help centralise the axle , before tightening everything. But also measure various points side to side. From the chassis.
Posts: 625 |
Mines the same- one finger fender to wheel gap one one side two the other. I asked the same question when I got mine, apparently this is normal, depends where the craftsman nails the wing on 😂😂😂
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Check the mounting brackets where the rear shock is bolted to the rear brake back plate. Mine broke and then the axle can drift a little. easiest way to check is to removes the parcel shelf and try to move the shock
No rear shocks - it has those Armstrong lever things, that I believe mount onto the U bolts.
