1 members (RichardV6),
223
32
Topics49,904
Posts838,088
Posts: 463 |
Started to replace the rear brake cylinders today. Removed the R/H rear drum and found the rear brake lining had become detached and I don't have a spare set of shoes on hand. Does anyone know the part number and a recommended supplier?
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 37,484 Likes: 989
Posts: 37,484 Likes: 989 |
Here you go- just give your local Motor Factors the number and they will cross reference it. Rear brakesOr BHM always have some in stock BHM in stock. Delphi/Lockheed LS1311 Springs etc
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
Try these brake part numbers, http://www.talkmorgan.com/ubbthread...rad-models-brake-part-numbers#Post613595I have used these parts recently and they were identical to the original parts I took off, so I can say from experience they are correct. You can use the numbers to cross reference.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Make sure the registration on the cup washers on the steady springs are good as when I replaced my cylinders and shoes a few years back one of them let go and locked the back axle solid, luckily I was backing out of my garage at the time it might not have been so funny at speed, nearly a Plus Six moment  .
Posts: 939 Likes: 21
Posts: 939 Likes: 21 |
On my 1994 +8 the rear brake shoes are Mintex MLR67.
Posts: 463 |
Thanks to all for your assistance, parts are now on order. After scouring the internet using every cross reference imaginable I could only find one vendor in North America who carried the +8 shoes. Thank goodness.
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
found these on the dreaded ebay
https://www.ebay.co.uk/itm/Brake-Shoes-GS6067-TRW-Set-GBS610-GBS651-GBS800-TKC294-9968570-Quality-New/233528889193?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
they claim to fit post 93 plus 8, mine is 94 but none of the part numbers seem to match???
link doesn't work so ebay item number 233528889193
Posts: 5,470 Likes: 476
Posts: 5,470 Likes: 476 |
If it is only the shoe lining that is worn or damaged then it might be worth typing in " BRAKE SHOE RELIGHNING" into your search engine... ?
Good luck in your search.
Brake shoes It'll save time in the long run and help a good dealer out they need all the help we can give them right now  .
