3 members (Liam1961, Zach, Soleng), 396 guests, and 55 robots.
+8Rich 91
Topics49,841
Posts837,316
I have been homebound lately and decided I will be doing the bafflectomy when things get warmer. I've tried to compile the great wisdom of others into a single procedure. Please take a look and offer any constructive comments you believe enhance/improve/illustrate/clarify. We do this in another collector truck forum I am in and it works very nicely. Then the final is shared amongst the many. It is meant to be a recommended procedure, but not the only procedure. Thank you.
http://www.talkmorgan.com/ubbthreads.php/galleries/622847/prelim-bafflectomy-procedure
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Thanks for that, it’s something I want to do........
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
The write up is good and describes the process well. I would just add that I found removing the drill bit from the cutter and spraying WD40 in to keep it lubricated worked much better, also I didn't need to use the hammer function just applied light pressure then let the cutter do its business.
In my case I removed the first and last baffles and kept the large 8 holed center baffle.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Bruce, you would not happen to have a video of that sound that now comes from your bafflectomy?
Stephen; I don't have a video but will try to do one so you can hear the sound, I imagine it is similar to the stage one sound.
Bruce
2013 M3W (Olga)
Thanks Bruce.
By any chance are you going to use an iPhone to take the video? Then it would be a very close, if not exact, comparison to my video.
All comments added...thank you. Will repost in the future with pictures.....
Great guide.
One clean up suggestion for your first page would be shorter links. It is easy to generate shorter Amazon links: click on share on the item page and it will generate an email with a (much) shorter link you can copy and paste into your guide, for example I got this for the first one:
I want to recommend this product at Amazon.com
EZARC Carbide Hole Cutter Heavy Duty for Stainless Steel, 1-1/2 Inch 38mm
by EZARC Tools
Learn more: https://www.amazon.com/dp/B01I4178R4/ref=cm_sw_em_r_mt_dp_U_DZrEEb8QFFAFG
2020 M3W
Or go to tinyURL.com.
Where:
becomes:
https://tinyurl.com/rntxhcz
You can even give your tiny links a custom alias name that you create.
Late 2012 M3W
You dont need the ref stuff - I always cut n paste just the product ID stem of the URI...
PS: also works for changing .com to .co.uk (etc) in some cases e.g. https://www.amazon.co.uk/dp/B01I4178R4
